got the car back tonight.all I can say is... wow.
superclean. the Mercury guys have really done a good job.
took some better pics (all other stuff was off my phone's camera).
also have a video which I will post soon.
first up, Dyno sheet
actually the auto does work really well. at least without a load behind. hope it holds up ok.
doesnt come off boost so much. the hill up to my house on one approach is very steep. previously almost came to a stop. now it just keeps pulling all the way
haha, you bet
havent done any off road driving so keen to give it a go sometime for sure.
when you're ready mate ...we'll take it moderately easy but challenging to start off with to get the confidence up....and go from there.
am in south brissy. plenty of guys around here that can pull us out if stuck :)
  • 4 weeks later...
hey mate any more updates?
fuel economy observations?
temps? etc
fuel economy is not surprisingly poor. 22L/100km around town 50% and highway 50%
update on how it drives - fantastic. power delivery is smooth and acceleration anytime is awesome.
no towing yet but just took delivery of trailer so will update more at end of April after a few trips to the track
  • 10 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
