how are you fellow members?
I have changed to twin Z32's on my RB26 and am running a PFC, and it is hard to start and dosent run the best,
Dose any one know how to change basic settings on the power fc via the hand controller..
or
Is there any way i can run only one z32 air flow meter and somehow brige or cancel out the other?
Thanx for all the help in advance
https://www.sau.com.au/forums/topic/353478-power-fc-help-r32-gtr/
well for starters select VG30 AFM as the airflow meters. but really you need to get it tuned mate. and no don't just run a single one. you then can only measure half as much airflow. why did you change to them if you don't need their higher airflow measuring potential???
hey thanx for the interest and reply,
i have just upgraded to a bigger single turbo, and just changed to twin z32's because i thought i needed them, but it looks as if i dont so since i have already wired them up i have decided to leave them, so the car dosent run the best at the moment, and also as i am batteling for space i thought it would be a good idea to run one z32 instead of two, i have searcherd the net and have found a few people who make close to 500kw with a single z32, dont know how true that is but it is moore power than what i am intending to make.
thanks for the help any help is welcomed......
They make 500rwkw because they split the signal (effectively half, so 250rwkw x2).
Can be done of course but not ideal by any means.
What turbo do you have?
Other supporting mods?
Sounds like you've been fed some bad advice overall mate
this is the pipe you need for twin Z32 on big single application, made by trust, very nice piece of kit
http://www.nengun.com/trust-greddy/suction-pipe
then on the powerfc as the others have said read the PFC FAQ
in a pinch you can choose VG30 and it should run and idle OK
if you are still having issues with VG30 selected view ETC, SENSOR SW CHECK on the hand controller and check out the values for AF-1 and AF-2 - they should be very similar and no black highlight
thanx guys i will post up a pic of my engine bay soon..
I have a blitz K28 turbo, 1100cc injectors, coolers of all sorts, stg1 cams, custom head oil return to the sump, i dont have the head restrictors as i have read bad things about them, i will post a pic up for you guys soon..
thanks for the help..
hahhaah i have talked to a few reputable shops that i dont want to name and they have explained the fors and against, but thats not the topic at the moment heheh,
so in all your experiance guys what power do you think a sinlge z32 afm can cope with?
How do you figure that?
You can't even see where the Z32 line goes :(
Clearly factory RB26 runs out sooner than both Z32/Nismo, but everyone already knows stock GTR AFM's run outta resolution around 300rwkw and Z32's can do more.
The Z32 basically reports the same voltage as the Nismo AFM after 500kg/hour.
The stock AFM hits 5 volts (ie max voltage) at just over 700kg/hour or about 26lb/min in old speak (which aligns with turbo maps). In the olden days (When I went to uni) the rule of thumb was 1 lb/min of airflow = 10 horsepowers. Which ties in pretty well with your number.
You can measure the AFM voltage off your PFC hand controller which then tells you (With reference to the curve) your airflow. Then go to the turbo map, match the airflow & the boost & you have the duty point for the turbo.
i meant when you said a single Z32 measures a lot less than 26 AFMs.
I'm confused!
Yeah I see what you mean. Depends on how you extrapolate the line I guess. Looking at it again there is probably not much in it.
I guess it doesnt matter much anyway as the PFC is looking for 2 AFM's.
nismoid. I believe he means a SINGLE Z32 AFM will not outflow your standard TWIN RB26 afms. so he's saying why bother going to a single Z32 when you could just have kept your twin standards afms. am I close?
A single Z32 will measure more than stock 26 twins though...
If;
- the assumption that RB26 nismos have the same response to Z32s, and
- the graph is correct
Then no, it wont. However, I doubt that RB26 nismos will respond the same as Z32s since the the Z32s are larger in diameter - it doesnt matter that they have the same guts (hotwire and electrics), the air speed will be a lot less due to the diameter. I'm just guessing of course.
FWIW http://paulr33.com/ has the rates as;
Single Z32 AFM 350rwkw
Twin RB26 AFMs 300rwkw
Twin Z32 AFMs 511rwkw
NFI why 2 x 300 = 511.....
I was just going by the graphs. So there is a fair chance I have it wrong. It depends on how you extrapolate the Z32 curve or even if it runs above the 4.25V shown.
It may be worth checking my PFC to see what the maximum AFM output voltage was to get an idea of how it relates to RWHP.
Nismoid: out of interest how many horsepowers do you reckon a Z32 is good for?
Stabby: I see what you mean - either 2*300=511 or the 300 or the 500 is wrong????
those stats are very wrong and outdated in my FAQ
FYI apexi list them as;
80m RB25 airflow meter can measure up to approx. 300ps (221kW)
80mm VG30 airflow meter can measure up to approx. 500ps (368kW)
90mm VH41 airflow meter can measure up to approx. 400ps (294kW)
*Output is calculated off of measurable air volume
they dont list RB26 std but i think twin Rb26 std max just over 300rwkw
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
