Hey all,Just got some parts delivered. Doing a head build for my RB25det.
Nice, what did you get exactly, what specs, and where from?
I am interested as I want to build up a RB25 head soon and I have been thinking of using Supertech
Using,
Tomei Procams 270/10.25mm
Solid lifter conversion
1mm Oversize intake/exhaust valves
Tomei valve guides
Double valve springs
Titanium retainers
Stem seals
Have a look around on the IPG-Supertech website. Very quick and very helpful..
Here is the link to the stuff I brought.http://www.ipg-supertech.com/cart.php?target=product&product_id=1301&category_id=853
yeah hopefully should sound good.
Nah not assembling myself, I lack the skills. Going to employ a good friend to do the head work for me.
The way the dollar is at the moment, you'd be better off buying straight from IPG rather than ebay, imo.
yeah just. well a 26 will but there are some considerations. like how much lift, duration etc as that affects how far out the valves go and the timing of their opening in relation to each other. the last thing you want is any valve on valve action. but yeah it should be ok.
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
