I think that was a legitimate speed camera flash because it seemed to come from the other side of the intersection? Then again, I don't remember another flash and my car is in this photo :/
Speed camera flashes have traumatised me for life.
If that's your 32 Jamie, it dumps quite a bit of smoke when you're giving it stick!
:laugh:
Mr. Windsurf (Andrew) said the same thing... O2 Sensors might need changing again.
Does it use the O2 sensor when you're full throttle? Could be too thin an oil or worn piston rings / turbo seals. Can't remember if black smoke is oil or fuel burning.
whitey blueish smoke is oil...
black is rich fueling...afaik
btw, how bad is mine? I have never checked other then in rear view... just with the screamer I can't imagine it would be much better?
Yeah, Andrew said the same thing, black.
Must be running rich.
Adam, yours blows a fair bit under load, but every car will do something on full throttle...I don't remember noticing anything as much as I did Jamie's. Sounds like you do need a tune Jamie :)
Nar you'll have to Nistune or PowerFC for a dyno tune...but I meant "tuning" as in getting everything running right. You might actually have an underlying issue as to why it's running rich under load. On light throtle / cruising it's usually an O2 sensor...but this might be injector, spark or timing related? Nothing to be concerned about unless it's fouling your spark plugs, it'll just use more fuel and might not be as powerful as it could be if it was running leaner :)
