that was quick lol 3hours....
seen it there when i picked up the gtr. was in mint condish. would have been worth paying for. even a bottle would have been suficient. now i just got to modify the gtr box so it can be installed into the 31.
if it aint broke dont fix it...
hmmmm my motto.
but im always breakin stuff.
hmmmmm
Gt3540 + Stainless Manifold + 3" Intake + 3.5" Dump Front
good for 350-400rwkw, turbo was bought from ATS( Adelaide Turbo Services) 3 months ago can call Bill to confirm.
$2500
-Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW, comes with Custom Braided turbo feed line, oil restrictor and custom turbo drain, water banjos etc
and 19psi actuator, also included is an hks alloy hard out let elbow to suit. Id CHRA is 706451-24
-Tune length low mount stainless manifold
-3.5" Bellmouth dump front pipe & catless pipe
-3" Silicon with alloy connector intake pipe
post-31991-1262941091_thumb.jpgpost-31991-1262941134_thumb.jpgpost-31991-1262941146_thumb.jpg
post-31991-1262941158_thumb.jpgpost-31991-1262941196_thumb.jpgpost-31991-1262941206_thumb.jpg
Water Methanol Cooling mist setup suit skyline r33 in excellent condition, kit is wired up ready to bolt in
$400
Includes the following:
Modified r33 skyline washer tank (also spare new trunk mount tank)
BLACK 150 psi pump
3 meters high pressure hose
Brass fittings
World class brass checkvave rated at 600 PSI and over 300 F
Injector that installs from the OUTSIDE of the pipe
Injector holder
Relay
Relay Harness
Fuse
Fuse Holder
boost switch adjustable from 1-25 psi.
various electrical connectors
Also comes with new spare tank and fuses/relays
R33 cross over pipe drilled and tapped
post-31991-1262941391_thumb.jpgpost-31991-1262941456_thumb.jpgpost-31991-1262941473_thumb.jpg post-31991-1262941573_thumb.jpg
Sard 850cc side feed injectors rb25det
come in fuel rail with fuel regulator, injector o-rings, collets, injector loom with clips soldered in and modified clips to suit, all bolts straight into rb25det, only 2 months old!
$800
Apexi Power Fc + Hand Controller Suit R33 RB25det
Comes with 310rwkw tune to suit rb25det with, 3.5" exhaust, gt35, z32 afm, sard 850cc injectors
$1300
Edited by FOOLBOOST
Hi guys,
Have the following for sale. Pickup preferred, unless you want to organise postage / courier.
17 inch Tyres + Rims
4 x Yokohama Advan Sport V103 (255/40ZR17 94Y) very good tread $800 (+$1600 new!)
4 x Bridgestone RE55s (255/40R17 94W) a couple of track days left in them $400
4 x Bridgestone RE55s (255/40R17 94W) 60 - 70% tread $800
4 x Dunlop V8 Supercar Slicks (280/680R17) 40% tread $400
4 x R33GTR Rims only with centre caps, reasonable condition a few marks $1100
RB26 Engine bits
Greddy Carbon Engine Cam Valley / Timing Belt Cover $300
R32 GTR Aircon Setup (everything aircon forward of the firewall, excellent working condition prior to removal for weight reduction) $100
Trust MX Front Pipes (goes from dumps to cat) dent in standard spot $250
RB26DETT Plenum / Inlet Manifold / Exhaust Manifold (6 Total) Gaskets Brand New $100
R32 GTR Clutch Slave Cylinder (good condition, upgraded to nismo oversized due to triple plate clutch) $40
2 x AFMs excellent working condition mesh not removed (removed due to D-Jetro) $100
RB26DETT standard dump pipes $50
Jap retuned standard computer (no speed cut, car made 270rwkw with standard engine/ turbos etc and this computer) $300
Misc
Nismo genuine boot spoiler internal damage but should be repairable $50
Earls Oil Stat – installs into oil cooler circuit to thermostatically control oil temp. Dash 10 fittings for easy installation. Also has ports for oil temp and pressure senders. See http://www.earls.co.uk/earls/catalogue/Cooling%20Systems.pdf PART # 501ERL $200
R32 GTR Silk Road Coilovers typical hard jap spring rates $400
Sub Box, fits 2 x 12 inch subs in R32 boot WITH rear strut brace. Made from 16mm MDF, including fittings $50!!!
R32 GTST Type M Driving lights fit in Type M front bar $50
RB25DET Alternator and Aircon Compressor Good condition $50 each
Low Ballers will be ignored, genuine offers considered. First in, best dressed and items not considered sold until payment received or pickup arranged. Get in on some bargains and help de-clutter my garage! Pics to come once the temp goes south of 40degC.....
Cheers,
Andrew
Blue32
Edited by Blue32
FOR SALE:
KTS Adjustable Tie Rod Ends - suits R32, R33, Cefiros and S14 - $100 - like these ones here
pair of R33 GTR standard side mirrors(complete in housing, wiring, mirror etc) in white, fits GTST or GTR - $50
Hi guys,
RB26 Engine bits
RB26DETT Plenum / Inlet Manifold / Exhaust Manifold (6 Total) Gaskets Brand New $40
Misc
Cheers,
Andrew
Blue32
pics added: Click here
NOW SEPARATING KIT
Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW, comes and 19psi actuator Id CHRA is 706451-24
$1600
Custom Braided turbo feed line, oil restrictor and custom turbo drain, and water banjos suit gt30 gt35
$150
Hks alloy hard out let elbow 2”-2.5 outlet” with silicon joiner and clamps to suit gt30 gt35
$120
Tune length low mount stainless manifold suit rb20det rb25det
$300
3.5" Bellmouth dump front pipe suit gt30 gt35
$350
3” catless pipe
$80
3" Silicon with alloy connector intake pipe and clamps suit gt30 gt35
$100
Sparco Bonnet Pins
$40
Billet Coolant Temperature Sensor Adaptor
$30
Car:
PowerFC (R32/33 GTR) + hand controller $850
2x Motul 4l 300V Chrono Oil $75 each
stock 32 GTR turbos $200
stock GTR injectors (new revision) $200
stock 32 GTR cam gears $40
stock 32 GTR harmonic balancer $20
stock 32 GTR dumps $20
Trust oil cooler (150mmx300mm) - use on engine oil at own risk, was in a car that spun a bearing $40
Computer:
4x tressels, white (1.8m x .7m) $50 each or $150 for all 4
1x satelite dish $50
Random:
Poker chips, 500 peice $40
DVD Box set series 1 of WPT $30
Scrubs Box Sets: $50 for all 3 or -
Season 1: $20
Season 2: $20
Season 3: $20
Futurama DVD Box Sets: $50 for all 3 or -
Season 1: $20
Season 2: $20 Unopened
Season 3: $20 Unopened
all i can think of atm.. PM me, all prices are pickup, happy to post at buyers expense
updated some prices, pics and details of pfc are here http://www.skylinesaustralia.com/forums/R3...nd-t303301.html
hey lads i have some wheels i need to sell they are 17 inch, with good tread, plenty of rubber, the fronts are 215/50 and the rears are 235/45, i must sell them i need money, $400 ono, im easy, just let me know cheers 0430 400 138- adam, call anytime, , there are photos in attachments!
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
