For Sale:
Apexi Super Air Flow Controller SAFC in top working order. No longer wanted.
$225
Cash ... not promises. Not inc postage.
For Sale:
Stagea tiptronic box with shift kit, new solenoids, fully serviced, ready to go!
$475
Cash ... not promises. Postage/freight for something this large not my responsibility.
Both items available for pick up.
No timewasters or dreamers.
KKR rear camber for s13/r32/a31 $170
KKR castor for same as above $170
Pineapples $80
Whiteline adjustable sway bar with with all mounting hardware $200
Autobarn OIl cooler/relocater,sandwhich plate,greedy oil filter $350
all prices negotiable
Located Adelaide south
PICTURES HERE
http://www.skylinesaustralia.com/forums/Dr...72#entry5034772
Genuine Recaro SPG 2 fixed back with Genuine Recaro R32, R33 side mount rail - $750 neg. (regency legal too)
R32 Carbon Door trims - $400 FIRM (the fit on these is absolutely awesome too)
235/45/17 Falken Ziex tyres, pair only, brand new - $400
Ceffy Fuel Tank - $50
Ceffy boot lid - $25 (some bog on it, but good for track car)
35mm bolt on spacers - $125 pair (got 2 pairs)
Nardi Steering wheel with genuine nardi boss kit to suit R32 - $250
PICS:
Edited by JD_CEF
Hey guys up for sale is a Stainless steel HKS front pipe - $250 This exact one from nengun
http://www.nengun.com/hks/stainless-front-pipe
Also a Grex Oil filter Relocator kit including a greddy oil filter - $150
http://www.nengun.com/trust-greddy/oil-filter-moval-kit including
Cusco Drag Rods, these remove the hicas unit completely to shed wait and replace the tie rods with much thicker ones - $250
http://www.nengun.com/cusco/drag-rod
All items are new still
Edited by /2on
Possibly interested.
PM sent
Hey guys,
Firstly I wont be online again for a while. So you must contact me via mobile 0402 902 759 (matt).
R32 Dash Vents, Middle and passengers.
Immaculate condition.
Can not be posted as Im away but can be picked up from Western Suburbs (adelaide).
$150, firm for the pair, no pics you know what they looks like.
R32 BITS
Nothing over $100
Here are bits and pieces just laying around which i dont need naymore. Over looking at them in the garage too. Some parts are GTR but they will fit on gtst.
sub frame $50
sway bar $50
front brakes, heaps of meat $100
front rotors, heaps of meat $100
air con condenster $50
power steering canester $30
washer bottle $10
window wipers $5
gtr or gtst air con pump $40 each
air con bracket $10
coolant overflow bottle $10
upper control arms (MINT CONDITION) $100
front guards black with green pearl (MINT CONITION) $100
glove box $10
dash, no bubbles, small crack where u barely see $40
standard rear bar $80
bomex front bar, needs respray and top ends where bolts go have been crack off, not that bad easy to fix $50
standard dump pipe $30
gtr and gtst hicas pump $30 each
gtr steering column $20
need these gone asap, need the money. I have heaps more stuff which arnt listed, just contact me on 0417 378 515
Gt3540 + Stainless Manifold + 3" Intake + 3.5" Dump Front
good for 350-400rwkw, turbo was bought from ATS( Adelaide Turbo Services) 3 months ago can call Bill to confirm.
$2500
-Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW, comes with Custom Braided turbo feed line, oil restrictor and custom turbo drain, water banjos etc
and 19psi actuator, also included is an hks alloy hard out let elbow to suit. Id CHRA is 706451-24
-Tune length low mount stainless manifold
-3.5" Bellmouth dump front pipe & catless pipe
-3" Silicon with alloy connector intake pipe
post-31991-1262941091_thumb.jpgpost-31991-1262941134_thumb.jpgpost-31991-1262941146_thumb.jpg
post-31991-1262941158_thumb.jpgpost-31991-1262941196_thumb.jpgpost-31991-1262941206_thumb.jpg
Water Methanol Cooling mist setup suit skyline r33 in excellent condition, kit is wired up ready to bolt in
$400
Includes the following:
Modified r33 skyline washer tank (also spare new trunk mount tank)
BLACK 150 psi pump
3 meters high pressure hose
Brass fittings
World class brass checkvave rated at 600 PSI and over 300 F
Injector that installs from the OUTSIDE of the pipe
Injector holder
Relay
Relay Harness
Fuse
Fuse Holder
boost switch adjustable from 1-25 psi.
various electrical connectors
Also comes with new spare tank and fuses/relays
R33 cross over pipe drilled and tapped
post-31991-1262941391_thumb.jpgpost-31991-1262941456_thumb.jpgpost-31991-1262941473_thumb.jpg post-31991-1262941573_thumb.jpg
Sard 850cc side feed injectors rb25det
come in fuel rail with fuel regulator, injector o-rings, collets, injector loom with clips soldered in and modified clips to suit, all bolts straight into rb25det, only 2 months old!
$800
Apexi Power Fc + Hand Controller Suit R33 RB25det
Comes with 310rwkw tune to suit rb25det with, 3.5" exhaust, gt35, z32 afm, sard 850cc injectors
$1300
Injetcors SOLD
Rest still for sale
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
