For Sale:
Apexi Super Air Flow Controller SAFC in top working order. No longer wanted.
$225
Cash ... not promises. Not inc postage.
For Sale:
Stagea tiptronic box with shift kit, new solenoids, fully serviced, ready to go!
$475
Cash ... not promises. Postage/freight for something this large not my responsibility.
Both items available for pick up.
No timewasters or dreamers.
KKR rear camber for s13/r32/a31 $170
KKR castor for same as above $170
Pineapples $80
Whiteline adjustable sway bar with with all mounting hardware $200
Autobarn OIl cooler/relocater,sandwhich plate,greedy oil filter $350
all prices negotiable
Located Adelaide south
PICTURES HERE
http://www.skylinesaustralia.com/forums/Dr...72#entry5034772
Genuine Recaro SPG 2 fixed back with Genuine Recaro R32, R33 side mount rail - $750 neg. (regency legal too)
R32 Carbon Door trims - $400 FIRM (the fit on these is absolutely awesome too)
235/45/17 Falken Ziex tyres, pair only, brand new - $400
Ceffy Fuel Tank - $50
Ceffy boot lid - $25 (some bog on it, but good for track car)
35mm bolt on spacers - $125 pair (got 2 pairs)
Nardi Steering wheel with genuine nardi boss kit to suit R32 - $250
PICS:
Edited by JD_CEF
Hey guys up for sale is a Stainless steel HKS front pipe - $250 This exact one from nengun
http://www.nengun.com/hks/stainless-front-pipe
Also a Grex Oil filter Relocator kit including a greddy oil filter - $150
http://www.nengun.com/trust-greddy/oil-filter-moval-kit including
Cusco Drag Rods, these remove the hicas unit completely to shed wait and replace the tie rods with much thicker ones - $250
http://www.nengun.com/cusco/drag-rod
All items are new still
Edited by /2on
Possibly interested.
PM sent
Hey guys,
Firstly I wont be online again for a while. So you must contact me via mobile 0402 902 759 (matt).
R32 Dash Vents, Middle and passengers.
Immaculate condition.
Can not be posted as Im away but can be picked up from Western Suburbs (adelaide).
$150, firm for the pair, no pics you know what they looks like.
R32 BITS
Nothing over $100
Here are bits and pieces just laying around which i dont need naymore. Over looking at them in the garage too. Some parts are GTR but they will fit on gtst.
sub frame $50
sway bar $50
front brakes, heaps of meat $100
front rotors, heaps of meat $100
air con condenster $50
power steering canester $30
washer bottle $10
window wipers $5
gtr or gtst air con pump $40 each
air con bracket $10
coolant overflow bottle $10
upper control arms (MINT CONDITION) $100
front guards black with green pearl (MINT CONITION) $100
glove box $10
dash, no bubbles, small crack where u barely see $40
standard rear bar $80
bomex front bar, needs respray and top ends where bolts go have been crack off, not that bad easy to fix $50
standard dump pipe $30
gtr and gtst hicas pump $30 each
gtr steering column $20
need these gone asap, need the money. I have heaps more stuff which arnt listed, just contact me on 0417 378 515
Gt3540 + Stainless Manifold + 3" Intake + 3.5" Dump Front
good for 350-400rwkw, turbo was bought from ATS( Adelaide Turbo Services) 3 months ago can call Bill to confirm.
$2500
-Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW, comes with Custom Braided turbo feed line, oil restrictor and custom turbo drain, water banjos etc
and 19psi actuator, also included is an hks alloy hard out let elbow to suit. Id CHRA is 706451-24
-Tune length low mount stainless manifold
-3.5" Bellmouth dump front pipe & catless pipe
-3" Silicon with alloy connector intake pipe
post-31991-1262941091_thumb.jpgpost-31991-1262941134_thumb.jpgpost-31991-1262941146_thumb.jpg
post-31991-1262941158_thumb.jpgpost-31991-1262941196_thumb.jpgpost-31991-1262941206_thumb.jpg
Water Methanol Cooling mist setup suit skyline r33 in excellent condition, kit is wired up ready to bolt in
$400
Includes the following:
Modified r33 skyline washer tank (also spare new trunk mount tank)
BLACK 150 psi pump
3 meters high pressure hose
Brass fittings
World class brass checkvave rated at 600 PSI and over 300 F
Injector that installs from the OUTSIDE of the pipe
Injector holder
Relay
Relay Harness
Fuse
Fuse Holder
boost switch adjustable from 1-25 psi.
various electrical connectors
Also comes with new spare tank and fuses/relays
R33 cross over pipe drilled and tapped
post-31991-1262941391_thumb.jpgpost-31991-1262941456_thumb.jpgpost-31991-1262941473_thumb.jpg post-31991-1262941573_thumb.jpg
Sard 850cc side feed injectors rb25det
come in fuel rail with fuel regulator, injector o-rings, collets, injector loom with clips soldered in and modified clips to suit, all bolts straight into rb25det, only 2 months old!
$800
Apexi Power Fc + Hand Controller Suit R33 RB25det
Comes with 310rwkw tune to suit rb25det with, 3.5" exhaust, gt35, z32 afm, sard 850cc injectors
$1300
Injetcors SOLD
Rest still for sale
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
