Items:
1992 R32 Skyline
Item Condition:
Dark Grey
RB20DET
Manual
HKS 2530 Turbo
FMIC
3" exhaust turbo back
KYB suspension
GTR Front Bar, Rear Wing, and N1 Boot Lip
Type M Side Skirts (have front bar as well spare)
Water Temp, Oil Pressure, Oil Temp, AFR Guage, Boost Guage all inside car
Turbo Timber
17 x 7.5 +26 & 17 x 8.5 +26 Work Rims (also have a set of KTS 17 x 7 rims)
Recaro Drivers Seat (have standard seat as well)
HICAS Lock Out Bar
Front Strut Brace
Nismo Speedo
I'll update if i have forgotten anything
Contact Details:
PM on here please
Price and price conditions:
$10,000 ONO cash no swaps thanks
R32 sedan skyline parts 4 sale
pm me with ok offers
rear wing, silver, working light
$100 ono
apexi safc, good working condition
$150 ono
greddy profec-b spec-ii ebc electronic boost controller
all there, unit, wiring, near new
$350 ono
rear seat and rear backrest
r32 sedan, magical condition
looks NEW
$200 ono
rear seatbelts and side panel, perfect condition
no frays, look new
$50 for the lot
pioneer 4-way speakers
not needed, $100 ono
mags- 4 off
17x8" with tyres
awesome condition mags, tyres ok
$400
thank you
FOR SALE :
Carbon Fibre Effect ABS Battery Cover !!!
To suit...
ALL NISSAN GTR'S SKYLINE R32 R33 R34
Cover Size is 7 1/4"x11 1/2" 185mm x 290mm
Covers your battery in a highly durable and very stylish ABS cover, resistant to all heat and chemicals.
Made from Aircraft grade ABS
SA sale only.
Please not this is CF look.
Perfect for the upcoming show season and is an excellent addition to any engine bay!
Comes Brand NEW and Complete with fixing!
This item is designed to fit most batteries, however in certain circumstances some modification may be necessary to fit your car, we accept no responsibility if this is the case.
PRICE : $55
Hey guys got few things for sale:
R33 HKS diff back 3.5" exhaust believe its a hi-power model....say around $300
R32 HKS hi-power exhaust mid section (from cat to the rear diff) think its 3.5" or 3"...$150
Vertex rear bar for an R32 never been used needs painting, has got a couple little tiny cracks....$200
PM me please
thanks
$100 ono
$150 ono
$350 ono
looks NEW
$200 ono
no frays, look new
$50 for the lot
mags- SOLD
REST NEEDS TO GO - OFFFFFERS !!
Up for sale are some stock parts that i have left over
R33 S1 Standard suspension $100
R33 S1 Standard turbo back exhaust $100
R33 S1 standard intercooler $50
R33 S1 standard front bar cover (not cut) maroon can sprayed, just used to use it to get through regency $100
R33 S1 rear tail lights Maroon $100
R33 S1 child support bracket for rear $15
Contact
Borko
0415 466 726
set of austar rims (one buckled but fixable)
15x6
tyres roughly 50% all round (one needs replacing)
4x100
$80
Rear Camber Arms to suit S14 S15 R33 R34 BRAND NEW NEVER USED - $100 firm
r33 s1 automatic tailshaft - $50
r33 s1 automatic shifter surround - $10
r33 s1 automatic shifter assy - $20
r33 s1 automatic brake pedal assy - $15
r33 s1 front bar maroon (hacked and scratched) - $20
r33 s1 front grille maroon - $20
r33 s1 standard side mount intercooler - $50
r33 s1 standard dump pipe + front pipe - $50
modified jza70 intercooler (inlet and outlet on same side) - $50
pm or call 0422314938
some pics, can get more upon request.
Edited by SkyHi_33
for sale:
2 x T28 stock GTR turbos off a 33GTR.
(14411-24U04)
88,000kms, no shaft play
want them gone $250 for both or $150 each
2x stock GTR dump pipes - $50 for both
buy both turbos, and you can have the dump pipes for free!
someone PLEEEEASE buy them
Nigel
North East'n burbs, I can deliver Metro.
for sale:
(14411-24U04)
Nigel
I'm guessing these have ceramic exhaust wheels?
Selling my wheels as i sold the car and no longer need them. They are
Speedy Wheels Envy MK III In Wet Silver 19 x 8.5 Front & 19 x 9.5. +35 Offset all round
Stud pattern 5x114.3
Tyres are 225/35/19 Front & 245/35/R19 Rear Achilles ATR Sport Tyres. All tyres have plenty of tread left and non camber wear at all.
Front wheels have 2 inches of dish
Rears wheels have 3 inches of dish
You will need a 8mm spacer to clear the front calipers which i will supply free.
Only one rim has some scratches on it but they are very light and can be fixed very easy.
Wheels are still under warranty and have the receipt
I want $1000.00. No time wasters please
PM Me if interested. I can ship but prefer not to. Located in Modbury
Edited by SIR_R32
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
