EOI
stock 34 gtt turbo 90ks
almost no shaft play... not of the car yet... as my new one is in the pipeline :D
ill have to check if the new one comes with lines n stuff.
will be off the car in a week or when ever someone really waves cash at me
$400
EOI
$400
PM sent
FS.
R32 GTS-t Type M 4 Pot Front Brakes (280x30mm) - calipers, rotors, caliper hardline. - $150 SOLD
JJR Coilpacks (RB20, S1 RB25, R32/33 RB26) - approx 18 months old - doesn't misfire or any of that rubbish. - $250 SOLD
RB20DET Coilpack Loom - good condition, no misfires. - $100 $50
RB20DET Turbo + Exhaust Manifold - turbo good condition, I never had a boost controller so was running on stock boost. - $150
RB20DET ECCS Inlet Manifold - complete with injectors, fuel rail, throttle body etc. - $150
PM/SMS. 0438858813.
Hey everyone up for sale i have a BRAND NEW good quality oil water line kit to suit RB20/25 with a gt series turbo (low mount) such as GT30 or 35/40
Includes:
2x 60cm braided water lines in -6 with banjo bolt ends and barb fitting for hose that runs around back of engine
1x 40cm braided oil line in -4
3x M14x1.5mm banjo bolts
banjo bolt end and banjo bolt for oil line
90 degree -4 oil fitting and nipple that screws into turbo
all required copper sealing washers
and a few other various 90 degree fittings that arent needed but come with it anyway
Asking $100
was taken out of packet for pic only
ALSO i have a blown c34 stagea turbo with op6 exhaust housing asking $50 ono
PM or call 0417 899 445 cheers lockie
R33 Series 2 Coil Packs - 6 of them.
Upgraded to yellow jackets as one of them was starting to break down occasionally, rest are fine. No idea which one was breaking down, but you get all 6 so great for spares if you dont want to fork out $400 for yellow packs!
$80 for all of them. NE Suburbs.
Still available. Will take $50 for a quick sale.
For Sale
Inlet and Exhaust Cam Shafts with Cam Gears off of a RB25DET Series 1 out of a C34 Laurel.
Price: $150 ONO, pick up or local delivery. Price is for Cam Shafts & Cam Gears Only, Backing Plate will be taken off - once I figure out how.
Got the following up for sale that i need gone, all located in the hills.
Genuine RB20 Water Pump - $80
Genuine RB25 S2 Water Pump - $120
^^ Both Brand New/Unused.
Cefiro Brake Master Cylinder, Looks almost new, hardly used - $50
HKS 2530 Turbo, in good working condition, minimal shaft play, nothing unusual for a ball bearing turbo. $1200 will be available by next weeekend as its still on my car.
Gizzmo EBC, later model with multi scramble feature. in perfect working order, removed due to not being needed. $150
RB20 Power Steering Pump and Alternator - $20 each
Pair of Enkei Circular wheels, PCD 4x114.3, 17x8 +34, in ok condition, few minor marks but nothing major - $250
Best bet is to contact me on 0407 633 573 as im not on here everyday, but PM's will be replyed to :yes:
Few Parts added, need these gone as i need the money!!
Edited by Jms_31
I have 2x gold drifttek for sale 17x8 5x114 not multi stud, not sure of offset but im guessing around the +34 mark comes with 255x40 rubber used but good, some light scratching on i think both rims will get pics up later
$550 all offers looked at, not all accepted
EDIT
because of where the car is parked i could only get a photo of the drivers side
colour, size, offset pics
for description of Hero tyres see >>Here<<
UPDATE 1 rim no good so price drop
1x 8.5" gold Drifttek $150
2x 255x40x17 $200
Includes:
Asking $100
pm sent
For sale are some Items off my 98 r34 gt-t
HKS GT 2540-46T, hasn’t done many Km’s upgraded to a bigger garret $1200 ono+shipping
Greedy 600X250X70 return flow FMIC, includes everything you need, clamps, joiners $320 ono+shipping
Stock rotors, plenty of meat left $50 each ono+shipping
Other items include
Qfm A1rm semi track pads 80% left $40+shipping
Stock r34 gtt brake lines $50+shipping
Stock intercooling piping$40+shipping
Located Port noarlunga S.A
0405326532
Please ask for pictures!!!
Hey all. I have a set of black drift teks for sale. They are 17x8 and 17x9 multi stud to suit Nissan. Tyres at 50% all round.
Asking $950 for the set.
Also have a Nintendo Wii package which includes:
Nintendo Wii with all fittings
2x Controllers with 2x nunchucks
Da Blob
Need for Speed undercover
Super Smash Bro's brawl
Wii Sports
$350 for the lot there
All items located at dernancourt SA.
Contact me on 0402 035 914. Can mms pics
Edited by Mowbuss
Bump
EOI
almost no shaft play... not of the car yet... as my new one is in the pipeline :P
$400
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
