Items:
X Force High Flow 3.5" Cat
Item Condition:
Used but in very good condition. No dents or scrapes
Extra Info:
Came off my R33. Was working well when i was using it. Mesh/honeycomb still intact inside. Its got the flanges ready to bolt on. Good upgrade from the stock cat's.
Contact Details:
PM me
Price and price conditions:
$100 but open to offers
Items:
2 x 12" Kenwood subwoofers in enclosure
1000w US Audio Amp
Item Condition:
Used in good condition
Extra Info:
left sub has small 3cm crack
side plastic tunnels both have cracks
but i have another set to just replace
Contact Details:
PM me
$350 for both o.n.o
R33 Brakes Front and rear, Pads are 80% and rotors are fantastic.
Slotted disks both front and rear
Complete Rear Drum Setup
R33 Handbrake cables
5 Stud hubs
$800
A fantastic upgrade for your R32/S13/A31 + Rear 5 stud conversion or a complete 5 stud upgrade for an N/A skyline.
Edited by JiN_MaN
Brand New geniune water pump for rb25 $100
Jap branded front strut brace to suit R32 $80
Pair of R32 projector style headlights with brackets for gtr grill $150
Brad - 0430033573 msg for more details or can send u a picture ;)
Garage Impul Recaro reclinable bucket seats
immaculate condition with rails to suit stagea/r33/whatever else
$800 the pair FIRM
interested but your pm box is full
can you go ANY lower for the pair? anything you need to trade for a slightly lower price?
cheers
2x Bee*R rev limiters
$200 each
you read right, not one but two!
Both set for 6cyl
one is missing the red knob from Rev 1. If it needs adjustment, you just take the white knob off Rev 2 and it works the same
Also have some R32 GTR interior bits and pieces, pics coming when my camera batteries are charged
also For sale:
to suit RB26 GTR
* HKS 87mm pistons & rings, fitted, used for under 100kms
* Attkd rods, fitted
* ACL race bearings - Part # 7M2428H-STD and Part # 6B2960H-STD = main bearings & rod bearings, new
* ARP main stud kit
SOLD pending payment
Hey guys,
This is an EOI as my old man gets his new car on the weekend.
White 1992 VQ Statesman SII 5L
Done around 200k and is in great condition mechanically and body wise, no accidents, few blemishes but good overall!
Come check it out, not many taken care of like this one.
Dual fuel, great for a daily.
Dont have any pics atm, but can send upon request.
Chasing 5k.
PM me with any queries!
Cheers
bump! 500$ or 450$ if pick up this week. (will chuck in some cheap tyres but will need replacing)
hey M I K E, sorry about the late reply, I don't know why I can't PM something about my inbox is full.
Well I live in Mansfield Park.
contact: 0466 111 838
cheers
beepee
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
