Need to clean out the garage as the old man told me to.
Series 1 spoiler - black - good cond has some marks on it tho - 50$ ono
Drivers side seat - worn - has a rip in it - still works bit stiff with the adjusters - 30$ ono
Passengers seat - good cond - works fine no complaints just the usual wear - 50$ ono
Rear seats - top and bottom - good condition usual bits of wear - 75$ ono
Door cards both sides - have holes in them for tweeters, bit worn - 30$ pair ono
Rear quarter cards - great condition almost like new just a bit dusty maybe some marks - 50 pair ono
Pm me for more info/pics
Aaron Buzz
post-78652-0-40239400-1298104166_thumb.jpgpost-78652-0-05344000-1298104189_thumb.jpgpost-78652-0-56277800-1298104209_thumb.jpgpost-78652-0-25014900-1298104265_thumb.jpgpost-78652-0-79031100-1298104296_thumb.jpgpost-78652-0-53208200-1298104323_thumb.jpgpost-78652-0-43592200-1298104343_thumb.jpg
r33 parts
driver door & mirror, glass $100 silver
stock intercooler $20
washer bottle $15
overflow bottle $15
bonnet verticle lock support $10
inlet manifold with sensors $ 30
subframe with all arms $100
stock front pipe with cat $30
steering colloum with ignition barrel with door locks and 3 keys$70
boomex sides maroon genuine $ 60
type m rear pods maroon $80
cluster $ 50
stock fuel pump $15
s2 drivers side window switch $30
starter motor $50
s1 front seats drivers rail needs work$50 pair
front cross member $70
drive shafts $60 pair
r32 parts
turbo good condition no actutor $100
center dash vent $60 mint
2 door tail lights $50 pair
after market front shocks look stock height $50
gtr caster rods with white line bushes $50 pair
4 door front seats $50pair
lca' $70 pair
stock fuel pump $15
diff has been shimmed with new oil used for 3 months on street $ 120
power steering pump hicas $50
alternator with loom $50
starter motor $50
a/c compressor has been freshly oiled $100
air con condensor with lines and fan $80
r32 gtr genuine front bar with lip and mesh ,needs small repair easy $350
r32 gtr fuel pump with sender $80
isoto steering wheel red $50
autometer lgf gauge 30 psi & cup $30
blitz timer $15
25mm bolt on spacers $100 or swap for 15mm or 20mm nissan thread
s15 front crossmember $50
r34 a/c compressor $150
r34 drivers door with glass red $200
located in adelaide athol pk text 0422030855 can mms any pics...
swaps for 32 gtr drivers seat ,s13/32 adjustable camber arms,toe arms,r33 adjustable rear camber arms
Edited by hcR324door
$220 Nismo floor mats in Black to suit R33. Exellent condition hardly used. PM or 0427999093 located near Parafield Airport.
And they were out of a GTR if that matters
Apexi AX53B70-P25 Turbo. steel wheel, ball bearing. only had on my car for the last 8months 2 months was only running 12psi the rest running 16psi (8,000km roughly).
made 241rwkw on 16psi with basic mods. can send dyno report if needed. reson for selling i want 3076r.
$1800 ono.
Have some bits and pieces lying around...
Full set of Aragosta/Tokoshima adjustable shocks, 6-way Damper Adjustable and Circlip height Adjustable, work with your factory upper mounts, these are brand new in the box, never used, bought them off a guy off ebay but never fitted them, come in the original boxes, suit R32 GTR $400.
Mint R32 GTR Factory Airbox, all clips and plastic intake snorkel $200.
R34 type RB26 Coilpack cover decal, NUR spec (I think?), light gold colour, good condition, $50.
R32 GTR/GTS-t Front Strut Brace, polished alloy look with removable ends/mounts $50.
Interior Rear 1/4 window trims for R32, average condition, $20 the pair, price reflects condition.
Standard S15 200SX front and rear swaybars, $20 each.
Autotechnica Red/Black sports steering wheel with boss kit to suit R32, $40.
Cannon muffler, 5" tip, 3" through the guts with short section of 3" pipe attached, used, $40.
Slightly negotiable on some items.
PM or 0412 957 615. Cheers.
Edited by NSNPWR
1-Full set of Pia rozza rims 5x114.3
Front 17x8+35 with bridgestone er3000 215 45 17 approximately 50% tread
Rears 17x9+38 with crappy 235 45 17 tyres
Being second hand rims they have some gutter rash
$500
2-Pair of SSR Integral A1
5x114.3
16x7+44
no tyres
$100
3-Pair of wantanbe style rims
15x8
5x114.3
with a pair of brand new yokohama 225 50 15
$220
Located around Pt Adelaide.
Contact by PM
Item: 18 x 8 +38 Racing Heart Wheels and Tyres Set of 4, Multi stud!
Condition: All wheels have gutter rash to an extent, will get better pics soon. Tyres have very good tread (225 40 18)
Location: Adelaide, willing to organise freight for interstate buyers.
Price and price conditions: $1200ono, or tell me you have R33 or R34 brakes with lines rotors and pads plus some cash rolleyes.gif
Other info: All tyres same size to keep attessa equipped vehicles happy, can be run with or without center caps as pictured bellow
PM me.
Edited by kidafa
Item: Series one/two center console with series one automatic gear surround, PERFECT for modifying for a manual conversion to avoid damaging your stocker
Condition: Very good, often treated with Aerospace protectent when in car
Price and price conditions: $80 ono
PM me :-)
Item: Series One Leather Shift Selector
Condition: Good
Price and price conditions: $40 ono
RB25 triple core alloy radiator. In good condition, some small fin damage on the back. All good apart from that, kept my 25 nice and cool on the track for 12 months, only selling due to it not fitting in the new car.
$200.
660cc Injectors to suit RB26 fuel rail
Rochester Type injectors.
Cost me $660 to buy and $100 to modify to suit rail.
Will sell for $500
Ran these in my GTR for 1 year, only changed them for 1000cc injectors for e85
Good injectors, never had any dramas with them.
Pulled some good power with them. Perfect for a GTR wanting to get in the 300+kw range on PULP
Located in Glenelg
G4 Adjustable suspension for R33/R34 GTR
MONO Tube large diameter series
10kg front 8kg rear (great for a street cross track car)
Great condition
Height and Compression, rebound adjustable 30 position
$700
Pickup avail
Matt
0413023669
Edited by BoostdR
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
