Parts from R33 S2.
Please PM enquiries.
Standard suspension - $80
Gutted stock cat - $40
Front rotors - $40
CAS - $50
headgasket $70
injectors in rail $80
throttle body with tps $40
Nismo Adjustable FPR $50
    • Hey guys/girls got some michelin Pilot sport tyres for sale got 80-85% meat
  • They are 245/40zr19
  • $150.00 for all four tyres very good condition left in shade not in the sun
  • Also got a R33 dumppipe/frontpipe $100.00 No brand
  • Can MMS pictures Message me on 0422 102 617
  • Located Parafield Gardens
  • Cheers Mark
For sale is mypride and joy R32 GTS Skyline YES A GTS!!!! non-turbo!!!! great for P-Platers.
Colour - Black
Transmission -Manual
Price - $11000
Mods that isdone to the car:
Exterior Mods:
Genuine GTR N1 Front Bar with lip
Genuine GTR Bonnet ( Super Light )
Genuine GTR Front Grill
Genuine GTR Side Skirts with rear Pods
Projector Headlights
17 inch Drift Teks Multi stud 8inch frontand 9 Inch rears both 35 offset
Both rear guards Rolled and Flared
Nismo Shocks and springs ( 2cm above legalride hight on both rear and fronts)
Tinted windows
red painted brake callipers
Engine Mods:
Pod filter (but also comes with originalairbox with filter
Front and rear sway bars
New Race Spark plugs (unknown brand)
Recently did Major Service done all beltsfrom timing and fan belts including pullies, all oils, changed water pump andnew powersteering pump, changed radiator and new break pads
Engine has only done 170xxx which is notmuch for a 20 year old car
Interior Mods:
Changed to LED for Cluster
Changed to LED for Interior light
Changed to LED for reading light
Brand new 2011 model Kenwood CD playerwith USB ipod connectivity
Recently Regased the Aircon
There is a lotmore Mods done to the car just cant remember from the top of my head, its agreat car drives like a dream such a pitty i have to sell due to family issueswhich needs my condition. can lower price buy taking things off such as CDplayer Rims and other things to make it cheaper, never been pushed and cant bedefected.
contact me on0433439293 any time or Email me at [email protected] for any questions
dont PM me tho.
thanks.
All black D1r rims like new , 2 drift pracs old . Sold my drift car no longer required .. 17x10+15 - 17x9+17 ! 60% tread up front on bridgestone petenzas . Rears have camber worn west lakes but will supply a brand new set of tyres for the rear included I'n the price
Can send pics on request
0431528958
$1000 firm
5x R33/s14 stockies with tread.
1 tyer is completely gone but still holds air.
The other 4 are good for skids or road but they aren't the best.
Rims are perfect, just a bit dirty.
$150 for all 5 rims and tyers
FOR SALE
R34 GTR V-Spec PARTS = Stock Front Mount Intercooler $200
Stock Radiator $100
Stock Cams and Cam Gears $200
Parts are all good cheap upgrades for a R32 GTRs, pretty sure cams are slightly more aggressive then stock R32 ones??
S13-14 Silvia PARTS = Adjustable Roll Center Bar $200
2 x Gold Koya Drift Techs, 17x9.5 $300 for both SOLD!!
I can MMS photos to anyone interested..
0408 878 086 or PM me on here..
Cheers Brad.
Edited by SHOWOFFR32
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
