HKS Silent Hi Power catback - suit R34 GTT
Has been on my car around 6 months and seen 2500km, has one small scratch on the bottom of the cannon where i recently bottom out on a mates driveway.
Comes with original box and paperwork.
$850 ono
Ben - 0433987945
bump
also have a just jap decat pipe to suit r34 gtt $50
Rays Te37 18 X 10.5 15 For Sale(2500)
HI,i have a set of te37 rims for sale.removed from r34 gtr and they are in perfect condition just very minor unnoticeable scratches .u will have to buy new tryes as this are worn out.they 18 x 10.5 15 5 -114 3 BR.if interested please contact me on 0402551649 thanks
look like 9.5s Edited by NISSAN GTR
Hey Guys!,
I have a series 2 R34 front bar for sale It came off my own skyline as I decided to go for another look.
The the bar comes with a series 2 front grill including badge and series 2 indicators with out the looms.
I priced the bar $60 as its taking space up and could be used by some one else.
Just to let you know this is a bargain as these bars usually sell for over $200 with out the indicators and grill which can be sold individually also.
If you have any questions please don't hesitate to ask .
Cheers.
Tom 0416153371
R32 GTST Bilstein Coilovers Great condition
-Fitted with a new set of Eibach springs
-Very good condition with no leaks, dents or any other markings aside
from general wear and tear.
-Height and damper Ajustable
-comes with dual springs on rear can be removed depending on set up.
-have only seen road use
$799 neg
northern subs Pick up
contact Alex :0421340064
http://i49.tinypic.com/2rddhfc.jpg
Edited by PSYKO
Set of Genuine Volk GT-C's in silver, 17x8 +35 Face 1 and 18x9 +38 Face 2. Fronts clear big brakes, they clear my brembos easily. Fronts in excellent condition, rears have a few small marks on the chrome lip.
Front tyres are stuffed, Rears have 245/40 Potenzas with a couple of mm left. Chasing $1000 for these. Which is well under the price i want for them but i need them gone!
Contact me on here or on 0407 633 573.
Need these gone, Genuine GTC wheel/lock nuts included. Offers Accepted.
Work Varianza T1S
5 stud Nissan 5x 114.3
F 18x9.5 +19
R 18x9.5 +14
all wheels in perfect condition one has small gutter rash ref to picture about 2mm wide easily fixed
front tyres 90% 225 40 r 18
rear tyres 70% 225 40 r 18
$2200 slightly NEG.
contact Alex : 0421340064
http://i46.tinypic.com/2ajyg44.jpg
http://i46.tinypic.com/osuxz8.jpg
Garrett Gt3540, used... but has been rebuilt by ATS and unused in box since
comes with braided water lines and a braided oil feed line for Rb30
currently has a 1.06 housing fitted, but i also have a .82 if you want that instead
i just want to go smaller now as its my wifes family car
$1200 no offers
Sard 700cc injectors to suit rb26, they are currently in the car and running but can be pulled out this sunday.
Only selling because i'm changing to e85 and need bigger injectors.
$600
0433943034
Edited by Drop_Kick
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
