Items:
BNR32 numberplate.
Item Condition:
used but good condition.
Extra Info:
includes 1 year plate agreement car in photo isnt icluded obviously..
Contact Details:
peter saunders 0415128693.
Price and price conditions:
$1000- ono
all off of a ca18det manual sil80
ca18 bare motor - sold
ca18 gearbox 300
ca18 tail shaft 100
ca18 starter motor 85 includes loom for it
ca18 full engine loom - sold
ca18 ecu 100
FMIC with ca piping 300
ca18 radiator 40
ca18 fuel rail 30
ca18 coil packs got all 4 with the bracket rail thing all 4 work mint they go for 40 each at wreckers say 100 for the lot
ca18 coil pack cover 20
ca18 brand new o2 sensor 60
ca18 front pipe 3 inch 30
powersteering pump hicas with bracket - sold
xtreme HD clutch and pressure plate good meat left 100
3 working ca18 injectors the other 1 has a bit broken on it ? will seperate single injectors make an offer on what you want i can send a pic of the broken bit on the one.
PM me thanks
motor , gearbox, tailshaft, ecu, fmic , 2 out of 4 coil packs, injectors, clutch sold.
ps pump ca18 back up for sale.
also got a sr20 power fc with hand controller 1000 ono still in box
HKS Silent Hi-Power catback to suit R34 Gtt. Good condition on a couple of minor scrapes on the bottom from my driveway, full 3/3.5 inch stainless. $650
JJR decat suits R34 Gtt only. $50 neg
R34 spoiler, Kr4 silver good condition. $100 neg
0433 987 945
A few items for sale. All parts are from R33 series 2
Brand new r33 Apexi Power Fc with hand controller still in box. (Manual) Never got around to fitting it just been sitting in the cupboard. $1600
R33 HKS adjustable actuator, bought from a member on here a few years ago but never fitted also. $75
R33 series 2 front bar with nismo lip (Kr4 silver in colour) $450
R33 series 2 bonnet (Kr4 Silver) $450
R33 series 2 rear bar $100
R33 series 2 spoiler $100
R33 crossover pipe $50
Everything is in great to immaculate condition.
Not on here alot so prefer phone contact, If i dont answer im at work just sent me a txt.
Cheers Brad 0409699742
Hey guys, got what looks to be a BN sports front and rear bar. Rear is in excellent condition in white while the front is decent but needs paint and a few little touch ups.
$200 ONO
PM for more pics or details.
  • Like 1
Got some spare stuff to sell,
Genuine R32 GTR plastic 2 peice side skirts - $150
GTR standard manifolds and heat shields - $80
R32 front upper arms with near new bushes - $80
GTR twin turbo pipe - $50
PM here or mobile is 0415117115
Anyone interested in a set of 4 Toyo R888 Semi Slicks? 265/35/R18. Plenty of rubber left. No flat spots or uneven wear.
I would be keen to do a straight swap for a decent set of 225/40/18
Or $500 for the set. Please contact via pm
sorry for large images!! I don't know how to reduce
Edited by Kenny80
Ball Bearing GT2871R
Just been rebuilt with MTQ, selling as no longer modifying the car.
Bolt on for rb20 and rb25
Has the largest nissan front cover machined out to retain stock appearance. Rear housing is .72a/r but can supply a 0.64a/r (still rb bolt on) for extra instead. Dump flange bolts up to standard exhaust.
Includes HKS adjustable Actuator, fittings in pic not included.
Can supply any extras needed on top.
$750
post-44040-0-74096600-1363686053_thumb.jpgpost-44040-0-99745500-1363686062_thumb.jpgpost-44040-0-75610600-1363686073_thumb.jpg
Volk racing 19' wheels set for sale
19x8.5 +21 19x9.5 +23
245 275 tyres front 30% left rear camber wear need replace
very good condition only 1 rim with scratchs
price nego or swap for other wheels
0431574766 Richard
0431574766 Richard
Link fixed: http://www.gumtree.com.au/s-ad/croydon-park/wheels-tyres-rims/volk-racing-19-wheels-set-for-sale/1010007017
You can't link it when you're logged into gumtree.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
