r33 gtst s2 manual turbo parts.
full 5 stud conversion r33 brakes hubs discs calipers brake lines brake pads etc. all 4 corners $650 ono
manual tailshaft - 80
hicas rear subframe - 20
power steering rack - 20
rb25 engine crossmember with engine mounts - 40
caster rods + brackets - 10
power steering reservoir and lines - 10
heater and air con box behind dash - 15
good carpet - 10
centre console - 20
hicas - 20
  • Like 1
Hi guys, had a customer bail on a RB25DET package including a 150,000km engine running perfectly with a series 3 steel wheel turbo, all ancillaries, AFM and 5 speed gearbox with a shifter and crossmember. If someone picks it up by NO LATER than 6pm tomorow they can have it for $2200, cheapest package from any wrecker in the country. Will be back to normal price if not sold by then. Thanks guys.
SOLD SOLD SOLD !!
Hey guys just selling the Koya rims that i took off my r33 when i sold it. I had them painted black after selling the car so they are pretty much brand new condition. They are suitable for big brake systems and also have a twin valve setup for letting out air in racing situations.
Fronts are 19 x 8.5
Rears are 19 x 9.5
Looking at getting $1100 for all 4.
post-77504-0-24115200-1371044281_thumb.j
Will ship interstate at buyers expense. contact me here but i will respond much quicker by mobile - 705 443 7240 (From right to left for spam reasons)
Hey guys,
time to let my Legnum go!!
1998 Mitsubishi legnum vr4 tiptronic twin turbo, Touch screen DVD player, factory nardi wheel, roof racks, weds meshies, tyres in great condition. Car has just been serviced, including new engine oil and filter, tranmission oil and filter, new O2 sensor and new front brake pads. Selling as I am building a house, willing to trade for a non turbo manual s13 or 180 plus cash my way. All offers and swaps considered. Buy it now for $9,800 or make me an offer!
http://www.gumtree.com.au/s-ad/mawson-lakes/cars-vans-utes/mitsubishi-legnum-twin-turbo-awd-wagon-swap-for-s13/1019449683
Hi everyone the follow items are for sale.
APEXi Power FC with Hand controller - For a Manual series 1 R33 GTST - In great condition - $850
APEXi AVC-R Limited Edition boost controller with an additional new control valve and all instructions - In excellent condition - $500
Z32 AFM with plug - In great condition - $180
Jun rear Pods - Black - need a respray but other than that in pretty good condition - $100
PM me for more details :)
The power fc mate will it defs not suit a series 2??
Nathan can you please post pics of the rear pods? I might be keen.
Also series 1 and 2 use the same PFC.
Hey all,
up for sale is a set of 4 5x114.3 with +37offset black/shadow 5 spoke rims with Bridgestone Protenza RE001 Adrenalin 225/50 R16 92W 80% tread left.
http://www.gumtree.com.au/s-ad/salisbury-north/wheels-tyres-rims/16x8-5-inch-5-spoke-wheels-with-bridgestone-protenza-re001-tyres/1021686902
500bucks ono!
PM if interested
PFC SOLD pending payment...
I will post some photo's of the pods as well Grimesy
Hey all,
500bucks ono!
PM if interested
SOLD
My track R32 4 Door if for sale
$5.5k, can be rego'd if you wanted
Details in the link below and more pictures.
Im selling my bran new unused and fitted extreme 6 puck solid button clutch with a extra heavy duty pressure plate. Reason for sale is I have upgraded my turbo and the clutch wont be able to handle 300+ kw, the clutch is suited to someone looking at making 250kw or even a little more. Comes with what's in the picture clutch plate, pressure plate and a new bearing (not the braided hose and fittings) I will get a better picture soon.
Suits rb20/25 push type gearboxs.
$500 ono
Pm me if interested
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
