Hi people.
I have a recon rb25det head for sale.
valves have been reseated, valve stem seals replaced. its been faced and crack tested.
comes with factory cams, and all cam caps and retainers.
only selling because I bought it before I pulled my old 25 apart assuming it was just a stuffed head,
then I found a recon long block and bought that also.
so now I just have this head taking up space.
its been sitting wrapped in plastic since it was recon.
asking $500 ono I payed $600 for it a couple months ago.
just want it gone.
pm or text me on 0420907228
can get pics is need be, but everything is wrapped in plastic.
post-12234-0-99110400-1387404801_thumb.jpg post-12234-0-83361100-1387404753_thumb.jpg post-12234-0-31564100-1387404933_thumb.jpg
Nissan Stagea C34
Forced sale. Very clean and tidy.
Series 2 RS (rear wheel drive) with rb25det neo engine and 4 speed tiptronic trans
Built 11/2000
151,xxx kms
Pearl White paint
Unmodified and in excellent condition
Imported by Sinergy Motorsport. One owner with books and full service history also done by Sinergy
Climate control
ABS
VLSD
16" Alloy wheels with good tyres
Twin sunroofs
HID lights
Privacy glass
6 stacker CD
Stagea floor mats
Alarm / Immobilizer
flip flop center console
Cargo barrier
Cargo cover
Tow bar
9 months rego
Everything works, just jump in and drive. Only selling due to recent upgrade
$6800. NO SWAPS. NO TRADES. Inbox me or call / txt O41O 34O 449
updated
gfb blow off valve $70
rb25det ecu turbo manual $60
RB25/SR20 injectors x 10. comes with a set of 6 in a r33 rail, and 4 spare $80
full loom, engine loom, includes coilpacks and injector loom, and also lower loom, starter knock sensor alternator etc, also includes ignitor. $80
Power steering pump $50
Tail lights, surrounds, bulbs, wiring etc $40
R33 engine mounts got 4, $20 each
R33 suspension arms $40 a pair. rear LCA, rear camber, traction, front camber castor etc.
Pair of 5 bolt drive shafts $80
Clutch master and pedal $40
Pair of 17 inch chromies legal tread $50
r33 x force exhaust deletes cat stainless steel, twin mild steel blast pipes $180
Posted 24 November 2013 - 05:27 PM
Lenso mesh type wheels
19 x10 +19 GTR Offset
5x114.3
One has a hair line crack needs to be re-rolled quoted $150 so far..but they were on the car tires held air didn't affect anything
$400
R33 GTR 320kph Nismo Dash cluster
White face..speedo not working and rev
Counter jumps all over the shop
$200-
Greddy intake pipe set
(Replaces the twin turbo pipes)
$600
R33 GTR Timing Belt Kit
-HKS Timing belt
-Permaseal seal kit
-GNB idler & tensioner
$250
HKS intake pipes
Bolt onto stock rb26 AFM's
$120 or swap for stock air box
R32 gts-t
Front calipers & cross drilled and slotted t
Rotors painted gold
$200
S14 front
Calipers and rotors
$200
Solid subframe bushes $100
R33 crossover pipe with blitz blow off valve $100
S14 front hubs lower control arms and knuckles
$350
0431 391 262 txt for pics
Luke
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
