Hi people.
I have a recon rb25det head for sale.
valves have been reseated, valve stem seals replaced. its been faced and crack tested.
comes with factory cams, and all cam caps and retainers.
only selling because I bought it before I pulled my old 25 apart assuming it was just a stuffed head,
then I found a recon long block and bought that also.
so now I just have this head taking up space.
its been sitting wrapped in plastic since it was recon.
asking $500 ono I payed $600 for it a couple months ago.
just want it gone.
pm or text me on 0420907228
can get pics is need be, but everything is wrapped in plastic.
post-12234-0-99110400-1387404801_thumb.jpg post-12234-0-83361100-1387404753_thumb.jpg post-12234-0-31564100-1387404933_thumb.jpg
Nissan Stagea C34
Forced sale. Very clean and tidy.
Series 2 RS (rear wheel drive) with rb25det neo engine and 4 speed tiptronic trans
Built 11/2000
151,xxx kms
Pearl White paint
Unmodified and in excellent condition
Imported by Sinergy Motorsport. One owner with books and full service history also done by Sinergy
Climate control
ABS
VLSD
16" Alloy wheels with good tyres
Twin sunroofs
HID lights
Privacy glass
6 stacker CD
Stagea floor mats
Alarm / Immobilizer
flip flop center console
Cargo barrier
Cargo cover
Tow bar
9 months rego
Everything works, just jump in and drive. Only selling due to recent upgrade
$6800. NO SWAPS. NO TRADES. Inbox me or call / txt O41O 34O 449
updated
gfb blow off valve $70
rb25det ecu turbo manual $60
RB25/SR20 injectors x 10. comes with a set of 6 in a r33 rail, and 4 spare $80
full loom, engine loom, includes coilpacks and injector loom, and also lower loom, starter knock sensor alternator etc, also includes ignitor. $80
Power steering pump $50
Tail lights, surrounds, bulbs, wiring etc $40
R33 engine mounts got 4, $20 each
R33 suspension arms $40 a pair. rear LCA, rear camber, traction, front camber castor etc.
Pair of 5 bolt drive shafts $80
Clutch master and pedal $40
Pair of 17 inch chromies legal tread $50
r33 x force exhaust deletes cat stainless steel, twin mild steel blast pipes $180
Posted 24 November 2013 - 05:27 PM
Lenso mesh type wheels
19 x10 +19 GTR Offset
5x114.3
One has a hair line crack needs to be re-rolled quoted $150 so far..but they were on the car tires held air didn't affect anything
$400
R33 GTR 320kph Nismo Dash cluster
White face..speedo not working and rev
Counter jumps all over the shop
$200-
Greddy intake pipe set
(Replaces the twin turbo pipes)
$600
R33 GTR Timing Belt Kit
-HKS Timing belt
-Permaseal seal kit
-GNB idler & tensioner
$250
HKS intake pipes
Bolt onto stock rb26 AFM's
$120 or swap for stock air box
R32 gts-t
Front calipers & cross drilled and slotted t
Rotors painted gold
$200
S14 front
Calipers and rotors
$200
Solid subframe bushes $100
R33 crossover pipe with blitz blow off valve $100
S14 front hubs lower control arms and knuckles
$350
0431 391 262 txt for pics
Luke
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
