Have some r34 gtr wheels with tyres for sale. Some gutter rash but still look good. Tyres are 235 45 18 federal fronts are about 70 percent rears are pretty bald. 1100 o.n.o and a full set of r34 gtr suspension in good working order for 300 o.n.o txt 0420945669
fs
r32 manual tailshaft 100
r32 gtr front hubs camber arm etc 100 a side
r32 gtr abs unit 150
r32 gtr standard intercooler brackets 50
r32 gtr brake duct plasticss 100
r32 wiper motor 40
180 tailights and centre garnish 50 a set
180/s13 door complete minus trim 50
r33 hks super dragger exhaust 200
r32 glass full set
bare rb20 intake mani 20
rb25 neo intake mani complete 150
r33 centre dash vents 60
  • 3 weeks later...
up for sale is my pride and joy, high powered performance gtst. which is also featured in the zoom magazine, previous owner had set this beast as a track car, also spending a lot of $$$ on it has one at import monster sau nats 2012 for quickest 800m mod 2wd class.
also at import monster sau nats 2012 800m highest speed mod 2wd class.
there is no back seats and carpet had been removed, has a bonds half cage $700 installed
has two r34 gtr bucket seats.
gtr rear end
omp race spec stearing wheel
a set of $700 defi din gage for oil,press,water,oil,temp
has a zetronic ethanol display screen $500
nismo gtr 320km cluster white $1000
phantom boost gauge $220
fully enginerrd certificates so hassall free
motor rb25 30 to4z turbo water and oil cooled
2000cc injectors areo flow fuel rail
all braided lines runs from engine to the boot and connects to a 5 ltr sard fuel surge tank with x2 walbro 450 in tank pumps
nismo in tank fuel pump to exterior
has an immobiliser built in too
x2 fuel location for exterior pumps
also has an e flex sensor so you can use petrol or e85 sensor and computer does the rest.
huge plenom with qhf 90 mm throttle body
Ross cas full balanced
drilled out oil remains blow off is plumped back
blisten shocks all new bushes
sway bars in boot engine bay under Neath sway bars
r33gtr wheels with brand be hankook tyres $1500 for set of 4
response head unit alpine speakers
brakes upgrade to dixcel type gs slotted rotors with zpads $2500
has also just put in a PPG dog box 1st to 4 gear straight cut 5 normal gear $8500
also has a nismo twin plate coper mix clutch but good friend jim berry had it supped up for me costing $3000 but strong guarantee it will last
r33gtr rear end 4:11
also eagle conrods, je pistons, custom exhaust camshaft (256deg) single coil up rated springs drain back vents on head drilled out oil returns rb26 cam covers with mines baffles external oil feed1mm restrictions full balanced QF45 throttle body high energy oil sump, tomei oil pump, factory Ross cass balancer, gready intake manifold, custom front mount inter cooler, Phoenix alloy radiator, custom 3.5 inch 5zigen exhaust system, high current igniter, link g4 plug in engine management system with link 2bar map sensor gready profec and electronic boost controller
the whole e85 fuel system cost $7600
car mad 450kw 601hp ran 11.08 at creek with old box be easy 10z with new box
car has receipt for every thing no joy rides no time wasters $27000 no less over 60k worth of grunt and power munches any thing on the road on low boost.
car also is featured in zoom mag custom plates SKYLNE also has 3 boost settings off is 14 psi low is 21 psi and a high 26 psi
call me on
0437797237
Pair of GENUINE Bride DIGO-R seats and rails for R33 GTS-T, purchased from Japanese Import Spares 18 months ago, seats are immaculate, no rips/tears/stains etc, just a little dusty from car being in storage.
Selling due to going to Cage and Fixed seat.
Retail for $1K a seat, and $200+ per rail, selling for $1200 as a complete bolt in package. No separating the pair, nor the rails.
Contact Ben on 0439 888 043, or PM here, Car is in storage @ pooraka but seats will be removed tomorrow and can picked up from modbury. Can also help with delivery.
Pair of 17x8 +36 wheels for sale. They have 'Hinodex' and Japan stamped on the back so I assume that's the brand (not a clue as they came with the car).
Currently have Federal RSR 595's on them in 205/50/17. Have plenty of tread left (99% of use was daily driving).
Asking $300 ono (don't be affraid to throw me an offer).
Located SE Adelaide hills.
Cheers, Brenton.
post-96537-0-39526200-1421827753_thumb.jpg post-96537-0-69868400-1421827776_thumb.jpg post-96537-0-84433900-1421827797_thumb.jpg
FS SA
R32 gtr door cards
customised to hold duel front speakers
flocking embossed with GTR logo
they came as spares with my car and they seem to have screws holding one sides trim, so not %100 condition
whats pictured is whats available.
$100 for both.
Cheers, Brenton.
attachicon.gifDSC_0025.JPG attachicon.gifDSC_0026.JPG attachicon.gif10937406_10206035340231886_1181093836_n.jpg
Price drop $250.
whats involved in getting these in a 32gtr as far as the rails do you know?
Should be a straight swap, I've had two mates put 32 gtr seats in 33 gtst so the reverse swap will fit
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
