Hey all :)
I own a 1998 Nissan Skyline R34 25GT with auto transmission, and whenever i tried to do wheel spin, it just can't get it up.
I have been told that traction control is on, so is there a way to turn it off? like there a switch i haven't seen? or yeah, someone please help me.
xx Ben
https://www.sau.com.au/forums/topic/354391-turning-off-traction-control-on-r34/
Should be a on/off switch by your left knee under the steering wheel. Pic is from my Manual 2000 GTT, im assuming the auto is no different.
yeah i have that switch, when i flick it, it comes up saying 'snow', is that the same as yours?
There might be a fuse box that can access and pull out the fuse for traction control..? Try losing traction at a wet parking lot by making slow doughnuts, I think a light should blink in the dash to indicate that the traction control is working/not working.
oh yeah i guess i could try pull out the fuse for traction control. i just thought there was a switch like other cars, may be wrong tho.
On R34s traction control is organized by modulating secondary throttle plate inside the throttle body. Look at your engine. Locate throttle body. There is no secondary plate actuator in there - none of N/A R34 have them from factory. Hence there is no traction control.
ohhh thanks, i'll give that a look and see what i can do. :)
Yep, thought NA R34's didn't have traction control, what on earth would they need it for? This thread is a perfect example for why they would never need it. The OP is TRYING to get wheel spin and can not achieve it.
well that sucks, i would have been nice if i could get wheel spin, maybe not then :P
Maybe you should try to induce some wheelspin using tallspeed of your auto box? press both pedals, it should rev up to ~2000 or 2500, then release brake pedal. If that does not help, then either you'll have to live with no wheelspin or put on some narrow tires or add ridiculous amount of camber to the back.
Note that stallstart heats up ATF pretty fast, so don't hold both pedals for a long time and don't repeat this exercise very often.
Added: according to factory manual, stall speed for RB25DE is 2350-2550 rpm. FSM does not recommend holding throttle pedal for longer than 5 seconds and also says to press throttle gradually. It also says to release throttle as soon as stall speed is reached, but you should release brake pedal instead and floor your throttle :P
Edited by Legionnaire
go to a parking lot
right/left hand down full lock
floor it and see if the orange T/C / SLIP blinks in the middle of the dash?
what you mean by 'right/left hand down full lock'
and what if T/C or SLIP comes up?
You won't see it, as R34 N/A's do not have traction control. At all, period. It just doesn't exist man.. I.E it is always off.
ohhh okay, thanks man :)
thats all i wanted to know
  • 2 years later...
i have a 34 GT-4 (the non turbo 4 wheel drive model) and im wondering why i have a TC button on my dash if i dont have TC? i dont have the on off switch so im just guessing that they made the same cluster for all manual non turbo models but why would they take the turbo gage off and leave the TC on?? im confused
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
