After researching I tried to fix this flat spot at about 3-4500rpm or so. I have tried setting the plugs at .8mm and it improved slightly. I have just bought yellow jacket coils and installed them thinking the old ones must have had it. If anything, it is now running worse! Good torque at up to 3000rpm and then it just goes flat and pulls a bit more at the end.
What on earth could it be?
Mods are:
Mail/road tuned Z32 ecu
Walbro GSS342 fuel pump
3" turbo back exhaust
GFB Boost T
K&N panel filter
Yellow Jacket coils
Running 11psi
cheers,
Dan
Edited by senilykSkylines
https://www.sau.com.au/forums/topic/354399-help-another-massive-flat-spot/
I would get a real tune done as apose to one of those mail order bride ecus! You may be able to make the car run better but not every motor is the same to run the same settings!
I did have a mail order but then the tuner did a road test to check that is wasn't pinging and that all was running fine. I've only notice the missing a little while after the tune was done.
So - The tuner reckons it was running fine during the road test (that is, no pinging OR flat spots OR missing) and you agree there was no flat spot or missing.
Since then its developed a flat spot and a miss - did those things happen at the same time? What has changed since the tune? How many kms has it been?
It's done maybe 5-10,000 km after the tune. It seemed to run fine around the time of the tune an it has been gradually getting worse.
I thought a miss was a flat spot? As in a stall in power, failure to ignite... possibly?
The spark plug gap and the coils have changed since the tune but I did those because I noticed it after the tune (not immediately) I hope it is not the tune but I was thinking possibly the airflow meter maybe? or wouldn't it be?
Nah - miss is where the fuel doesnt ignite at all, so it is rough running, running on 5 cylinders. Flat spot is just low power, but smooth.
I had a similair issue with a z32 ecu on mine..ended up going with a r32 ecu and seperate vct controller, the drama was the z32 ecu for some reason just stopped controlling the vct properly.!
Edited by honan
  • Gender:Male
  • Car(s):R33 GTS25t 1997
  • Real Name:Daniel
97 would be series 2, which means no igniter pack.
Ya, one of the last R33's made, when I had the new computer tuned we even had to change around a few pins that would not usually need to be changed.
What I don't understand is why would having new yellow jacket coils make it worse? They are new and suppose to be better.
I really hope i am not leaning out or my engine would be frying itself. I would have thought running it rich rather than lean would be what makes it go slower? Fuel pump is only several months old, unless there is a leak in the line after i installed, but then it wouldn't be pulling hard in the top end I would have thought.
I've emailed the tuner...
  • 1 month later...
Dynoed it and turned out to be (in theory) the intercooler getting too hot which triggers the knock sensor almost always at 4000rpm. FMIC is on the next to do list.
How does heat trigger the knock sensor? It's on the other side of the block, it's not affected by heat and has nothing to do with the cooler. Unless the heat is causing the engine to ping which would be strange because you said your tuner said it want pinging.
put the stock ecu in before to cause any damage. I had a pfc which had a tune for stock car and little more boost, sure the highest ping was 38 but it ran like arse. Put my stock in there yesterday and yanked out the z32 afm and it runs alot better, alot more power. If the tune is not on your car it's not for your car.
<i> Unless the heat is causing the engine to ping</i>
This is correct. Tuner sensed a "little pinging" on the dyno but the knock sensor was pulling it back sometimes when it sensed knocking. So it is not knocking badly at the moment, only a little when it is hot which the ecu picks up and takes care of. Goin to get a FMIC and try 98 octane instead of 95. cheers.
Your running RON 95 fuel on a GTS-T, and it has being modified for extra power? :(
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
