Hey guys,
I have a mate who has an r34 GTT 4 door auto with Traction Control. He has asked me to fit a highmount turbo and greddy plenum and fab his intercooler piping. He has already purchased a greddy plenum, but was told from a shop he was going to goto the you can't retain the traction control with a forward facing plenum. I had a quick look at his car today, and saw how big the throttle body / tc unit is, so I can understand why it won't fit, but I was thinking, maybe you could just cut the TC part of the throttle body out, and if I have to, weld a 2.5" hose tail to one side if there isnt enough room, and extend the wires, and fit the traction control butterfly in the inner guard or something?
If he can't keep the TC he doesn't want to fit the plenum, but I really want to put it on, as I hate the clutter of factory plenums. Has anyone ever toyed with this idea? Anything you can see going wrong with it?
Thanks
https://www.sau.com.au/forums/topic/354591-r34-traction-control-mods/
He won't do it if it gets rid of tc? Lol wut. Every person I know with r34 tc drives with it off. All the time.
Tell him to make his foot the traction control. Ie don't flat foot it in the wet and you won't need traction contol.
The reason that it would remove the tc is that the tc backs off the revs and won't let the car go. If you change the throttle body with a different one it won't work
Yeah I know exactly what your saying.. But he wants it, and it's not my car, so I cant tell him what to do. But not sure if you understand what I'm saying. The throttle body and TC unit is one piece, with two butterflies, and the TC has a control unit with motor... and I'm thinking of cutting it in half, so the TC unit is alone with its butterfly, control unit and motor, and plumb it into the cooler pipes in the inner guard, and just want to know if it will still effectively work.
Well tell him to go and pay someone else to do the work.
Obviously you are doing @ cheaper - gotta be harsh sometimes to people who don't think, you're doing him a favour as with a bigher turbo there is NO promise that TC will work correctly and not have an absolute fit 99% of the time as more power/less traction - and a bit of wheelspin will actually make it faster than TC totally shutting down the car
Your theory sounds good, put it into practice and let us know how you go :)
The OP suggestion will work in theory.
Also, I believe it was urtwhistle, modified his TC butterfly (shaved it down so that when it closed, it wouldn't fully close the opening) to allow a bit more power through when it kicked in, allows him to chirp 2nd pretty well now with TC enabled, instead of completely dying in the ass.
  • 2 years later...
Bit of a thread mine, but thought I'd add to this rather than create a new thread.
When the traction control is engaged, does it do anything with the engine management (pull timing etc) or just close the butterfly?
Has anyone drilled some holes in the butterfly or modified it to make the effects less noticeable but still retain some traction? I like the idea of it, but the effects are a bit harsh
I wouldnt bother.
When i got my car imported two years ago, it was kicking sideways with traction control ON. Of course they took all the parts off it when they complied it -.- , but still, TC will be next to useless with anything close to 200 kw atw.
Really you guys are telling fibs
My car with 350 at the wheels still has TC.
I love having TC on when i dont want to die in the wet....
It works...not as well as stock...but it works.....
My car has plenty of power and the TC removed, no issues driving in the wet...
Yeh I have this handy thing attached to my leg, right at the bottom there. Useful little thing commonly referred to as a 'foot'. The right one is pretty effective for keeping me alive, when it's wet I simply choose to not be an idiot.
TC can suck it.
  • Like 1
TC can suck it.
Haha :P
  • 1 year later...
You might find that the engine will go into limp mode shutting down the injectors with the sensor missing. Just had this problem with mine. Had to use stager with deleted TC. Also you can remove the butterfly from the TC as I had done prior to fitting my greeddy manifold.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
