Fantastic work!
I'm still a little bummed I didn't make my return trip home from the Nationals via Sydney, so I could stop by and have a look... though it did shave a few hundred km off the drive.
How far away is the engine build? Have you decided on all the details for it yet?
Fantastic work!
Thanks Ian.
It s ok maybe nextime you are in sydney John would be more then happy to show you the fab work and what his aiming to build.
The build has been slow, just getting the head ready for assembly as the bottom end is completed. ( Still trying to get pics for this )
All the other aspects of the car are ready and up to date, just need to drop the motor im and start finishing this build.
It's almost like the next pics you post couldn't possibly be better than what you've already posted...
But No.... They just get more awesome!
Have you weighted the manifold/turbo/gate assembly? Noted John thought it wouldn't need any brace/supporting. Just wondering what the actual weight is :)
The weight of the manifold with just the wastegates bolted on is about 7kg.
Spoke to John about the brace, he will be adding a brace or bracing system to the manifold however at this point of time he has not stated where. Once he does i will update you.
Cool thanks :) is it for clearance reasons. My 1jz manifold does the opposite (faces the comp cover away)
The turbo was rotated towards the rocker cover to achieve the best exit of the turbo that was not a 90 degree bend like everyone else has, john has said 90 degree bend can cause upto 15% loss in efficiency of the turbo.
Low mount manifold? Or does the comp cover face in towards the rocker cover?
This pic will answer your question
The red lines drawn on the inlet are approximate anti-surge slot locations to be milled out?
Sweet :)
I remember earlier in the thread it was stated it wasn't needed, perhaps that was only in early stages. 7kg + turbo would be quite a hefty end result.
Be interesting to see where it's braced and what not - look forward to that update :thumbsup:
Sweet :)
I remember earlier in the thread it was stated it wasn't needed, perhaps that was only in early stages. 7kg of stainless steel + heat + turbo would be quite a hefty end result.
fyp
heat + stainless steel = bending.
good welds will not stop it.
keep us updated. :)
The red lines are for the installation of a plunger infront of the turbo.
John does not like anti surge slots as this also reduces the efficiency of the turbo.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
