Wow that is a full on turbocharger Bobby I just realised...76mm inducer and 102mm exducer that should be nearing a four figure hp output.
It's a 68.5mm inducer and a 102mm exducer trim 44 this comp wheel is for high pressure ratio I'd like people to copy this theory. Currently modifying a hks turbo for a friend I'll post some results I won't say for now what I'm doing to it once done I'll let people know a nice mod for hks Kai
  • 3 weeks later...
Seriously thick walled wrist pins you've got there! They look to be at least 1-1.5 mm thicker than a standard pin.
I would have thought you would be using titanium rods too for the deck height you are running as well with this engine.
Is that a GT500 2.8lt crank?
Also, whats with the banjo fittings on the back of the head? External oil supply, rather than through a block restrictor?
Bobby, are the photos that you had of the head showing the water/air reliefs still on this thread? If not, can you post them up again please?
Looks great, like the red :) is that a anti-oil friction coating or it just looks cool?
Hi Ian,
John wanted the thickest wrist pin.
The rods are crower and this should be fine, and wont stretch.
Banjo fitting are the external oil supply that we can control how much we want in the head. Trevor the motor builder has said he wants to see more then std in the head.
Yes the crank is a Gt500 2.8L
http://www.skylinesaustralia.com/forums/topic/355547-r34-gtr-build/page__st__360
Yes that red is the Anti oil friction coating
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
