Be interesting to see how you go with the OS Giken box. A friend had a twin T67 R32 GTR with a Trust box that went bang so was replaced with the OS Giken sequential that also went bang. He was making something bonkers like 600rwkws from memory. He gave up on having that much power after the box problems with some of the thinking being that it was part shifting with all 4 wheels blazing in lower gears hurting what I think was 3rd gear. He was running a Fcon so wasnt running ignition cut which I think would make a big difference
Thanks for the advise.
Gearbox breaking is always the case in every high powered Gtr. Ignition cut does help however im trying to go the next step is having sensors in the gearbox for ignition cut to occur when the dog gears are lined up. Motec have done it with Hollinger so ill find out more and get back to you 8)
I have heard that the Hollinger is usually paired with an R32 GTR transfer case when installed in a GTR. The later model transfer cases are somehow different, and doesn't apparently easily (possibly at all) adapt to the R33/R34 transfer cases. (The person that told me this might have not had all the facts too, as seems to be typical for most high end GTR stuff)
I would imagine that becase of this difference, and how the R32 GTR doesn't run a preload on the transfer case it would also make the AWD system slower to respond. Perhaps potentially making the car a little more prone to power over steer compared to the r33/r34's tendancy to understeer. It realyl would be interesting to know if there is a difference. Ive always prefered the R32 to drive to the R33/R34's.
Internal sensor switches that detect when the selector forks are fully in the engaged position is definatly the way to go too. By enabling an ignition cut at the start of the shift and re-enabling ignition when fully engaged you will get the fastest possible reliable shift. Potentially faster than a fixed delay too. Safe shift speeds could vary at low RPM and road speeds vs high RPM and high road speeds, not to mention lubrication viscosity, temperature etc.
If the OS88 is a no hasle direct bolt in, there is no question as to which way to go. One of these is definatly on my wish list.
The Hollinger RB26 transmission will bolt up to any of the GTR transfer cases. There is slight internal clutch differences 32,33&34 but the overall principal is the same.
We've removed hollingers from 32's and swapped them straight into 34's using the 34 transfer case.
Same deal applies with the OS88.
Bobby have you looked into the Motorsport systems strain gauges.
I know touring cars guys who have done what you are contemplating with hollingers and they reverted back to one of Anthony's shifters for shear reliability and simplicity.
The idea of ignition cut isn't to kill ignition for the entire gear change either.
You only need to cut ignition to release the load between the dogs & engagement rings so you can actually pull the box out of gear.
Physically selecting the next gear with power applied to the engine isn't an issue at all.
Knowing when the selector is fully engaged is irrelevant, you only need to know when the gear is about to be disengaged. Strain gauges do the best job as they can anticipate the upcoming gear change by the force being applied to the stick and the Rate it's being applied (fast gear change vs slow gear change requires a different cut time for the time it takes to disengage the gear)
Hollingers old school micro switch "rocker knobs" are just an on/off switch that indicates the stick is being pulled and leaves the cut time to the ecu. It's a constant cut time and doesn't take Into account how hard and quickly the change is being attempted.
Hollinger and Os88 gearbox only fits an R32 or R33 transfercase as the R34 transfer case as a different bolt pattern.
Can you send me Anthony's details and ill call Motec to find out pros and cons about the exact setup
Am using a R32 gtr transfer case however going to run more preload so its similar to a R34 gtr transfer case.
  • 3 weeks later...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
