Just after some feedback on my setup after taking the car to the track for the first time with the new engine.
The engine is rb26, -5's and support mods.
Oil mods are, Nitto oil pump, Enlarged oil return holes in block, rear external oil drain to sump, custom 10 litre sump, tomei oil restrictor in block.
The engine is less than 500kms old and it has good internals
Took the car to a supersprint on sunday and the engine blew about 500mls of oil out the breathers into the catch-can. The rocker covers only have standard baffles.
https://www.sau.com.au/forums/topic/355563-rb26-blowing-oil-in-catchcan/
get better baffles in the rocker covers. Also how is ur catch can plumbed? If its connected to the turbo intKe try running it to atmosphere instead
Its running to atmosphere and it actualy blew a fair bit of oily vapor out the actual filter attached to the catch can.
Thats a silly suggestion. Clearly theres a more serious problem at hand, clearly only a bandaid fix IF it did do anything.
Too much oil in your head and you may eventually spin a bearing from oil starvation, the Nitto pumps pump alot of oil.
As others have said, a smaller restrictor may be needed.
Take car back to engine builder? What is his take on the problem???
Would I be right to just fit a different catch can that has a return oil line going to the sump? I could tap into the oil return line from the head and just fit a Y peice into the sump
Well then what you're doing is making a makeshift oil air separator...just buy the proper one as suggested
I dont think its a silly suggestion. I dont think he can really starve the sump of oil. Its a 10litre sump and i doubt the rocker cover will hold 10litres of oil.
Plus he already has a restrictor. He hasnt specified what size yet so cant comment on that.
It has a 1.2 restrictor fitted. And we also removed the spring in the oil pump to lower the oil pressure. I just thought with all of this done as reccomended here in the rb oil guide section that everything would be sweet. I thought wrong
U have done the mods by the sounds of it. Now u should get better baffles so only vapour can exit the rocker covers. As above u should get an autech style catch can/oil air seperator. There only 150ish from memory from ebay or just jap. This will hold a bit of oil under power if needed then once it gets a chance it can dump the oil back into the head
The Nismo can will not put an end to the sort of issues you have described.
Vapour (and oil) still finds its way into the intercooler. Enough to drip out the bovs.
You need to stop the oil getting to the catch can in the first place.
Are you running a PCV? Because if you are not then that will be half the problem.
If its not connected to the turbo intake (which he said it isnt) then it cant find its way to the intercooler unless a turbo seal is leaking
i think it will be the baffles for sure!
ive got a Autech Can on my car, and after a full track day on a hot day, it has had a smoky exhaust for a good 1-2hours after. i remember the first time i went to the Creek, it was a 30 odd deg day, my oil temp got up to 130deg at one stage, therefore would have been thining right out, when i got home that night i had my car just idling out the front of my garage and she was puffing a heap of smoke, i thought the turbo seals where gone or somthing, took it for a cruise no boost drive by the time i was back, it was all normal again. At the time my Autech was plumbed back into the intake, its now Atmo.....
Change the baffles man, let us no how you go!
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
