  • Replies 182
Posted Images
Go on the performance forums forum and read about besanko. Basically a workshop stuffed up bla bla bla and they left a gearbox on his front doorstep. Thats like 1/20th of a summary.
sweet shots mate! The S13 drifting is a money shot! Good work.
march goodness :) some wicked shots from matty and a few others :)
been playing around some more with a nikon 14-24mm f/2.8
mates band at the blaxland tavern
taps at the blaxland tavern...
coping a faceful of sloanes BBQ... that flame was small compared to the first one we saw... which licked up to the left hand tail lights...
random hot rod cruisin' past... it had a bourban and coke premix can as a catch can...
some messed up dude driving a bright pink riced up car... apologies for not knowing what it is... its an S something... but i almost threw up
FARCH has his car on the road... 180SX with a VH45 in it... that thing is a weapon! legally registered as a two seater aswell
and another shot
sloane's de badged R32 GTARRGGHH (he needs new GTR badges...)
Sean's (GTRSEAN) wicked wheels... the dude in the commodore was staring at us... as I was half hanging out the window with a big black camera in my hand
sorry no black and whites this month... good challenge though (I had some in late feb)
This is far from good, but i just wanted to show you all my car. Evo 8 MR, basically stock, just an exhaust and flash tune. 21psi of evo goodness. Will do a proper shoot with it in about a month when i get some carbon goodies and a better location.
This is the first proper photo i have taken of it since owning it.
Where are the BBS?
BBS was an optional extra. Usually always come with the Mica MR's. It seems like all the owners of them in Japland wanted optional BBS but no white owners did :( I'll take some better shots of the car this weekend and put some time into it :)
S14.5
Id Like it if it wasnt pink lol
About to leave for sydney, hopefully get some good shots while I'm there :)
So very gay.
yeah i was talking about korys double post. It is/was a bit of a shiitee car.
I'm doing some club photography tonight well hopefully its busy haha its not the busiest place but its a start...
Yesterday I went to the Top Gear live show in Melbourne, I took over 700 pics, but I won't give it away too much, I'm sure a few of you guys will be going to the show this weekend. It was AMAZING! Here's just a few that I like straight from the lens
Lens is a Canon EF 50mm f/1.8 pretty happy with it so far, and at $119 you can't go wrong!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
