thanks for the guide, great info to have all in one place.
any word back on the possibility of an HDMI input special?
Sorry, I forgot to post the reply I got last Thursday from "Richard" in China.
________________________________________________________
Subject: Re: modified TV tuner
Dear leon,
I got your meaning and transfered it to the manufactory. It is realizable to do that, however they have to change the components parts and it will make a big change of the inner structure and the outer shell.
One important point is not the cost, but the production run. The Min order to them is 500pcs, but I will do my best to discuss with them, please keep contact with me for this issues.
I'll ask them again once they've had a chance to think about it for a while. Hopefully they will be able to produce a couple of samples. Otherwise you might need to find 499 other people who want one :unsure: .
Edited by Commsman
  • Replies 144
big change to inner and outer doesn't sound at all positive.
and no, unfortunately i don't have 499 friends...
keep me posted, but if there's no positive news within the next week or 2 i'll just go with the normal version and put a converter in
Haha. I wouldn't know 499 people, let alone have that many friends either.. I will keep you posted tho
Cheers, Leon.
With the help of Leon, i got my tuner installed today!
AMAZING!
love it to bits, great install, top quality product with alot of features!
TOP QUALITY PRODUCT!
clear, even while driving.
Thanks again Leon. if anyone else wants any information on the tuner from a customer prospective... just ask me.
Aww, shucks :blush: . What a glowing review.
I'm glad you are happy with it. It was an easy install for me - you did all the work & I just talked about cars :thumbsup: .
It was just confirmed that the manufacturer won't do a small production run (less than 500) of tuners with a HDMI input.
They added the AV input to the ones I got becuase that feature was part of the existing chipset & didn't require too much rejigging. I think the HDMI input requires more extensive R & D.
Sorry, there's no good news. :(
12v HDMI to composite converter?
I think he has/can get an RCA - HDMI cable (or converter) but was concerned about loss of quality going from digital to analog & wanted to keep the signal digital for as long as possible..
I don't think there will be much difference since the OEM screen is low res anyway - unless the idea was to run it into a HD screen
I don't think you will see any difference in quality if you get a HDMI to RCA or composite converter unless you are running a 50 inch screen in your car?
Now there's an idea! I'll measure up the back to see if one will fit. The vehicles behind would love it if it was faced out the back... :laugh: .
  • 3 weeks later...
have got the TV tuner installed and works a treat. Really good product. I am quite surprised at signal quality. The reason I am posting this is that I would recommend the tuner to anyone with a V or M35.
Installation wasn't to hard either , for a novice like me anyway , lol
yes i have to agree it is a great product. I ended up pulling half my boot lining down and finding the 2 x clarion antennas and wireing them up. The only issue i have with it is the reception when i am traveling. When the car is sitting still picture is clear but when i travel it seams to drop out alot. I feel that around my area i get crap reception but that shouldnt account for everywhere. May also be my tuner box as one of the arial jacks snapped off the curcuit board and i had to solder it back on. great product and exerlent service
Was it the f-type aerial connector on the new tuner that broke Josh? If it was faulty let me know & I'll send you another one. You should get good reception pretty much all over Brisbane. There may be a few dead spots behind big buildings & hills, but my (very brief) testing there showed great results.
it was the very top arial f connector that you plug into. female port. ive never had good reception with my install. only when stationary. may just be a black sheep
I'll send you another so you can swap it out to test. Could also be a stray 'hair' of the shield braid touching the centre conductor on one of the aerial coaxs, but will be easier to fault find with another tuner.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
