Cut and pasted from another disco post:
700177-2 ... GT2835 52T with 84T turbine
700177-3 ... GT2835 56T with 84T turbine
700177-4 ... GT2835 56T with 90T turbine
So is the -3 the one to get for a stock RB25? What ID's does everyone else have?
I run the 4" Garrett 3076 with 3" reducer and have no issues. Now I know that the specs for the HKS are different and could do different things, but all things considered, I reckon you'll be fine with it.
Great to hear mate thanks for the first hand experience! So you run the reducer straight off the turbo then a 3" 45/90 deg bend to the afm?
Mine came with a reducer to the Intake pipe. I'm pretty sure its 4" on the turbo, definitely bigger than the intake pipe. I'll measure it on the weekend.
See thats the thing all the people on here that I have spoken to with the Pro S (joeyjoejoe, 75coupe and others) all have the 3" intake.
Are you sure the Pro S kits came with a 4" to 3" reducer at the turbo? As far as I know the Pro S kits have been discontinued and only the KAI is still made.
That would be great Fat_Tony, that would put the issue to rest.
Out of interest what results did you get from yours? Do you have a dyno sheet in the dyno thread?
No sheet. 345rwhp on 18psi. I think its a little low but my engine old and tired. Almost dead.
I have 700177-3 ... GT2835 56T with 84T turbine as well harey, 4" at turbo and 3" intake with black reducer. I think we have identical huffers but your dump is a little different by memory??
Im gonna run the 3" intake, my tuner (Unigroup) reckons its not a problem
Great to hear! My dump has been modified as the angle at the front pipe is different and there are lots of extra welds. My tuner is going to modify it.
Don't trust my fallable memory because it could well be 100 and 80mm .
All GT2835 Pro S turbos (AFAIK) used the -3 cartridge meaning the cropped 84 trim GT30 turbine and the 56 trim 71.1mm GT compressor wheel . I think other HKS variants used smaller trim compressors or the 90 trim turbine but not the Pro S one .
A .
Hey disco it appears that although Harey and I have the same turbo we have slightly different dump pipes.
Do you know anything regarding the hks dumps, as in was there a revised edition with a slight design change?
No issue stepping up the intake as long as it has a reasonable length intake pipe.
I have installed one of the early proS kits on a mates rb25 with the supplied 3-4 inch adapter and 3inch intake pipe and there was no stalling issue there. Stock bov.
I ran my 3071 rb25 with a 3-4 inch step and no bov and it never stalled.
I ran my old hks t300s low mount kit rb25 with a 3-4 inch step and a very tight type r bov that didn't open unless there was 15psi+ behind it and it never stalled.
My old gcg highflow on a high mount manifold with very short intake pipe, 3-2.5 step down and no bov stalled like a mofo.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
