Cut and pasted from another disco post:
700177-2 ... GT2835 52T with 84T turbine
700177-3 ... GT2835 56T with 84T turbine
700177-4 ... GT2835 56T with 90T turbine
So is the -3 the one to get for a stock RB25? What ID's does everyone else have?
I run the 4" Garrett 3076 with 3" reducer and have no issues. Now I know that the specs for the HKS are different and could do different things, but all things considered, I reckon you'll be fine with it.
Great to hear mate thanks for the first hand experience! So you run the reducer straight off the turbo then a 3" 45/90 deg bend to the afm?
Mine came with a reducer to the Intake pipe. I'm pretty sure its 4" on the turbo, definitely bigger than the intake pipe. I'll measure it on the weekend.
See thats the thing all the people on here that I have spoken to with the Pro S (joeyjoejoe, 75coupe and others) all have the 3" intake.
Are you sure the Pro S kits came with a 4" to 3" reducer at the turbo? As far as I know the Pro S kits have been discontinued and only the KAI is still made.
That would be great Fat_Tony, that would put the issue to rest.
Out of interest what results did you get from yours? Do you have a dyno sheet in the dyno thread?
No sheet. 345rwhp on 18psi. I think its a little low but my engine old and tired. Almost dead.
I have 700177-3 ... GT2835 56T with 84T turbine as well harey, 4" at turbo and 3" intake with black reducer. I think we have identical huffers but your dump is a little different by memory??
Im gonna run the 3" intake, my tuner (Unigroup) reckons its not a problem
Great to hear! My dump has been modified as the angle at the front pipe is different and there are lots of extra welds. My tuner is going to modify it.
Don't trust my fallable memory because it could well be 100 and 80mm .
All GT2835 Pro S turbos (AFAIK) used the -3 cartridge meaning the cropped 84 trim GT30 turbine and the 56 trim 71.1mm GT compressor wheel . I think other HKS variants used smaller trim compressors or the 90 trim turbine but not the Pro S one .
A .
Hey disco it appears that although Harey and I have the same turbo we have slightly different dump pipes.
Do you know anything regarding the hks dumps, as in was there a revised edition with a slight design change?
No issue stepping up the intake as long as it has a reasonable length intake pipe.
I have installed one of the early proS kits on a mates rb25 with the supplied 3-4 inch adapter and 3inch intake pipe and there was no stalling issue there. Stock bov.
I ran my 3071 rb25 with a 3-4 inch step and no bov and it never stalled.
I ran my old hks t300s low mount kit rb25 with a 3-4 inch step and a very tight type r bov that didn't open unless there was 15psi+ behind it and it never stalled.
My old gcg highflow on a high mount manifold with very short intake pipe, 3-2.5 step down and no bov stalled like a mofo.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
