  • Replies 95
I took the 33 to the whaleweigh station last week and found out its not a whale at all. Its a big fat pig. 1565 kilo full wet with me on board. Knock off 100 kg for me and its still a lard arse.
I was hoping for around 100 kg given the amount of stuff I've thrown out plus the full alloy gtr front end but when you add up what you put back it makes sense.
Steel 6 point cage, extra bracing, 30 bottom end, big brakes all round, surge tank and pump setup, even the hotside with the bigger turbo, himount and gate setup weighs heaps more than the standard item, bigger cooler, catch can etc. the list goes on.
Short of going full track spec and ripping it apart there's not a great deal I can do to get it down much further.
I am considering tossing out the alsd and all related hardware such as pump reservoir and lines etc so there would be a saving there but to keep it street legit theres not much more I can do.
Just wind the boost up a few more PSI to over come the weight...
Yes the ALSD does weigh a s**tload more Noel... I would turf it and replace with a mech. rear diff from a R33 or R32.
1465 wet without driver is actually not too bad mate for a car that is caged with track set-up brakes etc. at least you're man enough to weigh the thing and publish the number. so many people swanning around saying "my car weighs about 1200kg cause I took out aircon and the back seats" are living in fantasy land. the sad thing is that people hear it and then think "well fk me I want my 32 GTR to weigh 1200kg too". and then go and try to actually do it not realising just how bloody hard it is to get a skyline down that far.
This is my R33GTST,
it has a cage, as little interior as possible and none of the original wiring. Most of the sound deadening is gone. The bonnet is the only FRP panel. The drivers door is the only lightend part.
note there is only the brake line remaining.
the 1 cut out door, I run a window net and there is normaly an unbacked black carpet trim that covers the hole.
nothing much under the dash
but has a dash
Various cage shots`1`
fuel set up, 1/2 std tank full
with out me in it
first weights with me in before levelling the car
now for the fun to start. This is the first time I've done this so any help will be welcome, whats next????
This is my R33GTST,
but has a dash
with out me in it
Mik at Signature Now has carbon doors, dash, Front splitter diffuser aero bar and passenger side headlight with cold air intake available for the 33 Nod.
Theres quite a few kilo's in that lot if you can afforsd the stuff.
with out me in it
this should help http://grassrootsmotorsports.com/articles/understanding-corner-weights/
Noddy, have you done anything to the boot?
I pulled mine off the other day and it's rather heavy, the shocks and hindges were about 3kg in total alone, was thinking of cutting out all the innder webbing of the boot, piss off the hindges and run pins/straps.
The two post wing needs a bit of strength in the lid so not yet. I am looking at getting a carbon boot using pins and a better wing. That will have to be a little further down the track, when the wallet is fatter.
Thanks for the info Harry, will be giving it a go tomorrow night.... with some drinks so anything could happen!
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
