hey
the other day i made a phone call to CES (Custom exhaust systems) and they told me that an R33 gtst skyline has stock 143kw at the wheels. they than told me that they have an exhaust system worth, $1900 that will give the car dyno proven 180 to 188kw at the wheels, and after that installing a kn or decent air filter, and turning up the boost to around 11 or 12 they can produce up too 200rkw, do u think this is true, because they say they have dyno proven results and if it is than the car would have to be pushing high to medium 13 second times, wouldnt u think? can someone shead some light on this topic becasue im sure if its true than alot of poeple will want their exhaust.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/
CES are very good, the only complaint I have heard of is the price, but as the old saying goes "you get what you pay for". And I think in this case from what I heard its true. Dunno about there power increases though, 200 rwkw could be achieved with their list plus a decent intercooler and aftermarket ECU (powerFC). 200 rwkw without even a SAFC seems a little far fetched to me, I am pretty sure around the 200rwkw mark is limit for standard turbos anyway, give or take a few. Depends on the condition of your engine also, so many variables!
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-712231
would you stop f.ucking stop double posting everything you want to say on here on different sections, and in different posts?!
...kind of annoying, and its not going to get any better response. In fact you'll probably get less so because it shits people.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-712233
Generally speaking for a 33, and gauging by other members results, would I be wrong in guestimating this?...
130-135rwkW - Stock
140-150rwkW - Full 3" Exh & Air filter
160-180rwkW - Full 3" Exh, Air filter/Feed/Partition, FMIC, 12PSI, Fuel Pump, SAFC.
180-200rwkW - Full 3" Exh, Air filter/Feed/Partition, FMIC, 12PSI, Fuel Pump, SAFC/PowerFC, Exh Cam Gear.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-712690
interesting results...
i would assume that 40kw increase is not at the wheels
intercooler, 3in double dump and increased boost from the higher flow would probably give 200kw
$2000 would almost get you a intercooler installed and maybe a catback exhuast, id spend the extra 500 and get the double dump and finish off the rest of the exhaust at EXOTIC EXHAUST.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717012
130-135rwkW - Stock
I doubt you would be able to get a GTST into a true 200RWKW without changing the turbo, and if you could it is just a matter of time until you need a new turbo anyway.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717017
definintely not something that would last or recommend however what i suggested would be the absolute minimum to get even close to 200kw
sorry if i mislead n e one
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717305
i dont think it would be hard to crack 200rwkw on the stock turbo. I got 181rwkw atm with the mods in my sig on 10psi, and i reckon with a exh cam gear and 12-13psi and a bit of tuning would get me 200rwkw. The turbo is fine at the moment i dont see how an extra 20kw would kill it. But i do agree that it will reach its "safe" limits then and i will look into highflowing.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717708
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
