How do you run your air flow management system?
63 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
has anyone tried doing this with an AFM? I'd like to do the same but in the cooler piping instead of the intake.
That is actually quite common. Ive read about it in the past. People with cracked AFM housings normally extract the housing components and fit them into metal pipes for strength and looks. I guess it wouldn't give any performance gain but if your housing is cracked/damaged it would be a great option rather than buying a new AFM. Also a small hole in a intercooler pipe is easier to patch up rather than a piece cut out. I was considering this approach if I do decide to run my AFM in the cooler pipe, just not confident on how resilient the Z32 parts are to vibration and knock from the tools. Wouldn't be hard to seal it imo. My brother has this black stuff in a tube which sticks literally everything automotive.
What setup are you planning to run Sarge?
Im going highmount with the stock plenum so im thinking about getting a pipe like on Roy's car made up.
The issue is where would be the best place to place the AFM considering the wiring and also I think the pipe will have to be 3" to make that AFM in pipe mod possible so ill probably need a reducer at the radiator join or do the entire cold side in 3".....
I guess high mount makes it a little more challenging if you're running the cooler piping in the standard location, unlike the image you posted. You also need to consider the wiring because the turbo will be way too close to the wires and the heat wont be good. A low mount setup, the wires will reach as I did do a trial fitment in my old car. I needed 2 3" to 2.5" reducers to sit the AFM between my piping. Really stupid move to upgrade the size of the whole pipe system without upgrading the throttle body to a larger unit.
I'm going with AFM infront of turbo with metal intake pipe! I would have loved a MAP setup but I am not going to hunt down another ECU.
Edited by SargeRX8
Standard position with a z32afm, pod adapter one end and stock standard turbo inlet pipe on other end but with that reinforcement ring in it (to stop it sucking shut...which some people claims don't work).
z32 afm in the cooler pipe.
always been happy with gtr bov, but it leaks on idle (found out when we installed it in the position of the turbosmart one) and because it was located too close to the afm it was causing problems,
so we had to get something we could tighten extra hard with no leak on idle - so had to get the turbosmart - but didn't want anything wanky so it is part of the stealth range, can't hear it at all... but thats due to the screamer :devil:
Downside is obviously this looks far from stock... upside is I have no issue of revs dropping when u get on boost and then clutch in and the car nearly stalls... another upside - if cooler pipe pops off before the afm I can still drive the car fine off boost.
post-36975-0-57600200-1300027662_thumb.jpg post-36975-0-01462600-1300027677_thumb.jpg
meh, I run map sensor with a motec ecu in one GTR. the other GTR runs twin AFMs with trust hard pipe kit, the silvia runs Z32 AFM on a alluminium intake pipe to the turbo. all set-ups work fine. I honestly don't really have a prefference for one or the other, but I will say most tuners seem to be able to more consistently get better results with AFMs. I've seen so many map sensor cars running poorly it's not funny.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
