Hi guys
Just a quick question. I want to know what the size difference is between the M35 and C34 S2 factory intercoolers.
If anyone has the sizes can you please post them up and pics if available.
Thanks guys.
Edited by slippylotion
Yeah I'm thinking of getting an wgc34 rsv as a daily driver and thinking of fitting an m35 intercooler to up the boost on the factory turbo to 10psi (don't want nor need more power than what this will make as I have a 270rwkw 180SX sitting in the shed for when the mood hits me) on the NEO.
Seeing as the m35 run about 12psi I can't see this being a problem.
Thinking of going this way to keep as much air flow to the rad and not have to cut the reo or bar up and more cost effective than a fmic kit.
Does anyone have an M35 stock cooler the want to sell?
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
