The Autech R32 "26" was a bit of a fizzer in my opinion. It was a pretty boring looking R32 with less power than the GTS-t Type M at almost twice the price new. They were also all autos.
Not everything Autech does is gold. They also produced the R32 "Driving School Sports Sedan" version which was about as base model as it gets.
lol yeah got the brochure for the driving school one...
BUT it comes with 2 sets of pedals dude lol... i wanna own one of those... actually no, my mates will always press the accelerator when i go past cop cars n take corners.
Autech just makes speciatly cars, ones that factories don't make, but the public wants. Its not necessarily a sports tuner. Tommy Kiara, Impul and Nismo on the other hand are sports tuners.
these look liek and interestign engine
there was one of these car for sale on yahoo ages ago they were auto and 4wd and 4 door. 250 shouldnt be hard with a few tweaks ie cams etc
Water cooling serial 6 cylinders * DOHC Cylinder
Inside diameter x distance mm 86.0×73.7 Entire aerodynamic volume displacement cc 2568 Compression ratio 8.5 The highest output
PS/rpm 220/6800 Largest torque
Kgm/rpm 25/5200
  • 8 months later...
Interesting engine.....
Compression wise is still the same with the RB26DETT?
If it does, I wonder if It drives.
It's a nice rare engine. But I don't think it worth the price since now adays you can get a newer engine fron Nissan (even in NA) that has meet the 206kw japanese limit (on paper).
  • 3 years later...
  • 1 year later...
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
