Hello everyone,
Bought my 2002 Stagea AXIS a week ago, very happy with it so far!!!
Thought i'd jump on here and meet others and hopefully learn more about the car itself.
first mod that comes to mind is fitting an Apexi turbo timer, seeing even a 2 minute drive up the road to the shops driving it sensibly (under 3000rpm) and letting it idle for 30sec's before i turned it off still made it unhappy on startup.
on the longer drives its alright i try and keep it of boost before i get there and let it idle for around 3mins and its alright, but i feel its going to piss me off waiting on every little trip........ and this way the motor will alway be protected.
i'll put up some pic's of her but she's just the normal stock silver axis.
cheers, LAMBCHOPS.
https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/
Welcome, hope you enjoy your stay. What state you located?
There is plenty of info here about mods and options and power, susp, brakes etc etc
If you have a question, check out a search first, it might have been covered before- if not post away!
just updated my profile, im in western sydney...... ive already spotted another M35 in my area :)
was hallarious the 2nd day of having the car a guy comes up to me at the servo and asks if its a volvo...... (yes ive read all the storries on here) i just pissed myself laughing cos it only took 2 days.
the plugs are fine, car was serviced when i got it.
it starts fine other than when i think i havent let it cool enough before shutting it off.
havent got any pic's of it yet other than the ones i took off carsales..
no goodies on it that i know of...... which i reakon is a good thing.
the mod's im considering so far is:
BMC air filter, fit an oil temp guage and pressure guage, and a cat back exhaust.
cant even hear the exhaust note over the turbo whine LOL :(
nice i wish i bought an AXIS lol.
oh i have a dump back exhaust im trying to sell that bolts right up to the stock dump? whistling.gif
i wouldnt have bought anything other than an axis the others look like dog's balls LOL plus the extra's are awesome.
to bad your interstate, altho the axis is 206KW so that exhaust probly wont help me much aye
Haha, more like 130awkw though, we don't measure at the engine... :whistling:
I think the AXIS looks like balls, thats exactly why I went the AERO. :)
Exactly what I think & did, although I wouldn't like to criticise another man's car (out loud). As long as your happy witth your choice, that's all that matters.
As far as the list of goodies goes, some of the other models can come optioned up pretty well. Mine is an RS and, besides the Aero body kit, has leather electric seats, dual sunroofs, TV, tilt down mirrors, alarm/central locking, & probably other stuff I've forgotten. And because it didn't come with the fully integrated dash, can easily accomodate aftermarket GPS/DVD/bluetooth/Ipod etc device.
I'm not too sure actually what's left besides a LSD & heated seats (yuck... :yucky: )
Heated seats are damn good in winter. But on several occasions I've bumped the switch without realising it and my balls gets toasted..
yeah i just went on a 4day weekend with the boys and they thought it'd be funny everytime i wasnt looking to hit the seat warmers FFS might have to disable them.......... they're really not neccessary.
well to clear it up alittle, its the noncolour coded bars etc and the subaru outback stance, it just looked better with the 18's and the flaired wheel arches.
mind you i do have to say altho the grill and front bar match with the wheels i must say the front is the ugliest side to look at.
but in saying that im not gonna waste 1000's on replacing the front with a R35 for the sheer dollar facter and besides it would take all the fun out of the car by being to recogniseable HAHA
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
