What do you mean exactly by "i dont have a mould" did you have a mould b4 you offered this group buy? or were you going to get $$ from ppl, then buy a mould, then make the lips?
Blitz, you may not be aware how rare & expensive a genuine series 3 lip is. As I understood it, Sherrid was testing the waters to deterim interest re fibreglass lips. If there was enough interest then he would try to source a lip from elsewhere to use temporarily as a mould.
  • Replies 67
yup, i know how rare and expensive they are, as im trying to find the lip myself. I jus wondered how he was actually going to make these lips if he didnt have the mould.
If he is still looking for 2 more ppl, I would like to put my hand up, and i can get my mate to buy one also.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
