From what I've read yes depending on the brand is how well, like the is a difference between the godspeed and isis, cheaper knock offs vs. actual Greddy but trimming will be required.
The best way is to get your gasket and use it as a template.
Again this is just from reading.
There was a DIY somewhere jsut can't seem to find it ATM...
Hopefully someone else can chime in that has actually done it, hope this helps... Good luck!
  • Replies 155
anyone know if a rb25det forward flacing plenum will fit on to a rb20det?
No, the intake ports are completely different.
Don't know about making a flange adapter like people do to use the RB26 ITBs and plenums on 25s.
Some companies do make forward facing plenums to suit RB20.
Some are complete replacement upper and bottom, others just replace the top half.
https://www.plazmaman.com/shop_itemdetail.php?itemid=133&cate=38
I am looking to buy a lsd for my rb20e a31 cefiro. and found one on my local "buy and sell site" in New Zealand. It has a 4 bolt backing plate but my one is got a 2 bolt backing plate. but on the auction it says that it can some with a s13 subframe to suit. Will the s13 subframe bolt straight in?
here's the auction
http://www.trademe.co.nz/Browse/Listing.aspx?id=602743045
  • 4 months later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
