Hi guys and gals, so I have built a new forged RB26, with 270 10.8mm tomei cams and a 70mm billet turbo (slightly bigger than a t04Z), problem is its very laggy, it starts to make boost around 3500 1-2 psi but takes till about 5700 to get up to even 8-9 psi and then full boost of 19 at about 6500. I have adjustable cam gears and want some info on how advancing or retarding inlet/exhaust mght help my lag problem to make the car more responsive.
Im quiet aware that big turbo = lag, but this is a bit frustrating.
I had an rb30 with t04z and it would not come on boost with your foot on the brake and flat out on the gas standing still. We went drag racing and it ran a 13.6, spoke to a guy in the pits who said to roll the cam 1 whole tooth to advance the cam timing, next pass was an 11.1!!! It came on boost at least 1000 rpm earlier!
So just want to know if it might work the same way with this engine. Any opinions would be appreciated..
Thanks Christian
https://www.sau.com.au/forums/topic/358466-cam-gear-adjustment-to-reduce-lag/
You will make - some - more torque down low adjusting the cam gears, however its like pissing in the ocean to top it up. You might change the level, but you wont really notice it. Your turbo to engine to tune match is wrong, simple as that :action-smiley-069:
But in a freezing Southern ocean it can really help to warm the inside of your wetsuit, or so I hear.
I'd rather a healthy area under the curve at the expensive of peak power than visaversa, both at the same time would be nice but you can't have it all, unless you go to extremes. I dropped exhaust housing size to gain response and mid range and never looked back.
it amazes me that we need to retard and advance valve timing that much on an RB to get a better deal in the performance stakes down low..........bit like robbing Peter to pay Paul.
Nissan clearly had no idea what they were doing when they structured the RB's valve timing :/
Why such a big "f off" turbo mate? Why not go with something slightly smaller to get good value out of the built RB26??
Im building a spool stroked 3.4 liter motor next, just wanted to spend some time doing the new motor so I built this one to fill in the time..Im sure i'll have no problem selling it when the new motor is ready to go.
Im quiet aware of the lag issue with a big turbo, just wanting to know of peoples experience with varing the cam timing to counter act somewhat the large frame turbo hence the tread in the first place.
Its running a .81 exhaust housing, 4 inch dump, and 3 inch exhaust but the exhaust will be upgraded very soon to 4" all the way.
Don't get me wrong its great fun to drive but just wanted to get the spool time down as low a is possible with the 26 capacity motor.
Thanks for your feedback everyone
Edited by chrisking666
retarded to -4 is generally the consensus for Rb26 exhaust cam gear setting
not too sure on the intake, advanced to +1 or +2 ?
I was thnking the same thimg myself, I have retarded the exhaust cam 4 deg and it has definatly made it come on earlier prob 500-700 rpm earlier with no sign of falling over in the top end.
Im waiting for the adjustable inlet cam gear to arrive, I ordered 2 and only one turned up! pain in the arse really but when it gets here i'll advance the inlet 2 deg and see what happens.
Cheers Christian
a shot of nos low in the rev range would get the turbo spooling faster. or something as simple as a smaller intercooler so there is less volume to be pressureised by the turbo. i binned my omg look at me whale baleen cooler and put on a smaller unit, still get same power but less lag.
something like >>>THIS<<< could help improve the effectiveness of the cooler.
Thats what I'm trying to do, save buying 2sets of turbs's I'm going be running the gtrs's on the 26 with a small ARC 70mm twin entry cooler with cam gears and see how I go. I know it's gonna be laggy as Fu*k but time will tell.
If your mind is set on that particular setup, go and see Martin, get the thing tuned for Hoon Juice, then not only will you be able to throw a bunch of valve & ignitition timing at it but extra boost too.
That'll help with what you're looking for.......plus a few extra killawasps which can never go astray.
Krishy even has a cigarette hanging out of his mouth whilst pouring the stuff into his tank :yes:
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
