I know boss its getting all crunched up at the moment an producing a lovely amount of axel trans? I think that's what it's called
Tramp, well thats what i know it as. The biggest thing it affects is the bump stear which will make the car very unpredictable. again your choice but i ran mine at optimal height and never had the thing do anything unexpected.
Keep it low and once its out of your system you will see the difference.
pushrod v8.. you know you want one
i changed to an east/west 6 cycl na all wheel drive and couldnt be happier. nothing wrong with a v8 (had a calais once) but just dont like the aust cars. Would consider one of the new ford supercharged v8 things (GS?) but thats just because its go silly power from fact and with little to no help gets tons more.
  • Replies 804
Yeah I have to take the coilovers out to get the yellow of so I will definitely be raising it up. Will also make it easier on changing wheels up at the track so I don't have to cart pine blocks around with me :)
I've got a bit of axle tramp when dropping the clutch in the wet at low rpm, once she's running again I need to get a pro to have a look.
Got my freshly machined crank, bearings, Reimax oil pump gears, new timing belt and oil pump gasket ready to go, just waiting on access to the workshop!
I like budget. It is my favourite. I went up to the track and one of the trainers was like you need this this this and this and then he was like it's only gonna cost $1200. That is like my yearly centrelink salary :\
centrelink blow big chunks. We applied to have rent assistance (along with other stuff when i lost my job) and we were only going to get 10% of the rent back!!!! so out of $200 a week they said it was fair to get $20 extra. no wonder people cant afford to buy food each week.
on topic,
what did they tell you to get griff? did you find a r32 mani?
on topic,
Steering rack spacers, rear camber arms, castor rods, those solid bushes for the rear subframe and something that adjusts toe? I can't quite remember exactly what it was :)
I just ended up doing a botch job on the mani and drilling out one of the holes so it would fit on nice and snug.
Wasn't really to worried about it because as soon as the yellow comes off the mani with the gate flange will be going back on.
you can get adj. bushes instead of complete arms. they should do you till you get better and will cost less. i would suggest caster rods but again the bushes are fine everthing else is nice but not essentual till later.
cool as long as it works till then you are laughing.
Yeah I'm thinking about just saving the money and getting arms so in the long run its cheaper but I have to get it back over the pits first hahadomokun.gif
I'm not having to much trouble with it at the moment but I just want more lock and a bit more traction whistling.gif
MOAR TRACTION?:laugh:
Rebuilt the bottom end on the weekend and drop the engine back in the car, now to hook back up all the wiring and piping.. if the weather holds off and nothing else pops up, should be driving by the weekend :banana:
Yeah I need to start thinking about building up more speed and a bit quicker so I can get longer slides happening :P
Keen for a noob to come down watch you doing the wiring?
Bushes will be fine, dont cheap out on the arms get very good ones that can be serviced.
:cheers: fingers crossed.
If you want to come learn some stuff and lend moral support, I'll be trying to spend a couple of hours each night after work on it :thumbsup:
Thanks mate!
Sounds good to me :)
You still have my number from way back? Probably lost in your PM's due to the fact that you are a mod and receive all kinds of important things these days domokun.gif
Glad to hear it's coming along Bubba. I've cleaned my garage out and moved stuff i wanted to keep into the shed, threw out 2 trailer loads of "crap" just gota put the wheels on the car and move her into the shed to start playing
Cheers mate! Bet you'll be happy to start tinkering on the old girl again :P
I'm itching to go home and work on mine.. stupid day jobs :( Also need a 26 p/s pump bracket otherwise I'll be getting a massive workout driving around town :laugh: stupid ATI balancers :dry:
Yeah its been sitting there way too long, missus is starting to push me a bit more which will help. Bart had a 26 sitting down here, he might be able to help out with that bracket
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
