  • Replies 68
Given that the regulations for speedometers is +/- 10% accuracy, this is incredible.
Does this reg not also apply to speed cameras and guns themselves aswell? Im sure they also have a degree of inaccuracy.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729899
I've actually heard from some one who works in the nsw gov, that all this is happening because the state is broke
Knock-on effect:- Keneally is actually doing O'Farrell a favour > to take a step towards balancing the budget.
In regard to your relevant comment Owen, O'Farrell is on record to have stated, "I want greater police presence (rather than fine people off the road)"
He wouldn't have to repeal an RTA intention as it hasn't been enacted yet.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729921
funny how the governments in sydney are the ones that are broke and struggling and rather than finding positive ways to re emberse themselves - lets say take a pay cut for instance... on there almost obscene wages. they target the easiest and slyiest way to get "quick" bucks without any real retaliation and the sucess rate is going to be massive, not just for import drivers but all drivers.
what ever happened to the give aussies are fair go slogan?
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729980
i think it would be fairly easy to torpedo this by disputing fines through court again and again.
Given that the ADR's give +/- 10% at 40kph you could argue that purely due to aus design standards that it is impossible to regulate your speed to the required standard.
The only way to ensure this (at 60kph) would be to drive a marked 6kph slower than the posted limit, with the possibility (due to above +/- error) of actually going 12 km under the limit (48 kph) and as such possibly obstructing traffic.
Win that argument a few times... job done.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5729993
It is a good point, but, how many people fined with doing 61 in a 60 zone are going to opt for the legal option? I would say, and I am sure this is an assumption of the RTA/Government also that the vast majority of these people will simply pay the fines.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730011
i think if it were uncommon to be fined for that kind of offence you'd be right, but given the spike in cameras thats also planned, it would mean that being pinged for 61 would become quite common.
As the point hit is what would really hurt (i dair say the fine for 1 over would be low) i think disputes could go up.
Plus if someone gets one case dismissed based on my above suggestion, i think news would spread and it would start to snow ball.
that said... i can also see them updating the ADR's to make +/- 0% the requirement and then defecting you when you dispute it.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730033
Personally i think its the opposite
If you look at what the execs in big business get paid, and then look at government, i think the problem is that its such a low paying job for the amount of responsibility and stress, that no half intelligent person would actually even attempt it. End result is we get people in power like those we have now, from federal to state to local. No one with any actual background in running a major enterprise (which is what govt is).
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730061
unless they change the ADRs surrounding speedo readings and calibrations there is no way if you took a 61kph fine to court would it hold up
Why? Have you read the ADRs?
Everyone has been statng that it's +/-10%... But that's incorrect. The ADRs actually state a speedo has to be +10% accurate, NOT +/-
That meaning, your speedo can show your actual speed, OR upto 10% over your actual speed.
https://www.sau.com.au/forums/topic/358645-bang/#findComment-5730189
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
