Anyone done this? Looking to try it out to get a higher position for the blade.
Extended height legs bolted to the original GTR wing end pieces, holes in the extended legs to line up with the orignal blade with multiple angle mounting points. using 3mm aluminium, have a drawing penned to work off, but questions are:
will the material be strong enough to withstand downforce f Long straights?
Any foreseeable issues?
Is it worth doing?
Considering to make a new blade with the aluminium as well but wider (on the narrow side) to have greater surface area. Ie more area= more air can be redirected = more downforce
Any ideas and contribution much appreciated thanks
https://www.sau.com.au/forums/topic/358657-gtr-wing-extended-stand/
seen it done a few times in japan. can't remember off the top of my head who makes the 33 GTR kit though. it does look a bit funny to be honest but it's certainly functional.
  • 2 months later...
Mate got this one from guys in china,very good quality,comes with stays and mounting brackets to boot, but dont need to use those as wing sits straight in original wing mount.have tested it gives great downforce.I do have heaps of areo front splitter and diffuser rear diffuser and now the wing.These wings are only 360 us and 150 us sent to you door.look great as well. pics attached Company is on ebay called [stonecarbon2009]post-7486-0-29488600-1307680637_thumb.jpgpost-7486-0-76179300-1307680656_thumb.jpgpost-7486-0-57882400-1307680719_thumb.jpg.have bought a few things through these guys great comunication and very well made carbon.
  • 3 weeks later...
  • 1 year later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
