Hey guys,
Need to know if the car below is street legal before I buy it, this will be my first skyline :)
The skyline is a 95 R33 Gts-t and has CP Forged pistons & rings, front mount intercooler,Modified plenum,
25/30garret roller bearing turbo(1500KM)spitfire coils, 38mm external waste gate,EMS 8866 computer,
walbro fuel pump, blitz blow off,aluminum radiator,14row oil cooler, extreme clutch,18" momo rims, short shifter gear lever,
full 3"stainless steel exhaust with high flow cat,GTR body kit.
Any help would be great.
https://www.sau.com.au/forums/topic/358796-is-this-car-vic-street-legal/
no. and thats from a Qld point of view.
I dare say the first time you getr pulled over in it the thing will get a canary. if you are looking at buying it - don't unless it is engineered.
remove:
ecu
external gate
BOV
Fix exhaust (i have no doubt its too noisy)
And no doubt need the factory airbox fitted.
cooler perhaps, depends how its been mounted
If the EMS computer is a full wire-in, you are basically stuffed. Don't buy the car. More stuffing around that it'll be worth.
Do any of you guys know this car?
http://www.carsales.com.au/all-cars/private/details.aspx?R=10297264&__Qpb=true&Cr=1&__Ns=pCar_Odometer_Single|0||pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|0&keywords=&__N=12161246 1247 1252 1282 4294963846 4294963593 443903&silo=1011&PriceTo=443&seot=1&tsrc=allcarhome&__Nne=15&trecs=35&__sid=12E85BCC1CB0
I just spoke to one of the guys from Pro-Tek that did all the work on the carand let’s just say there was an odd story to go with it all and I don’t reallywant to flame anyone, just want some background info.
There are 1,000's of R33's around dude :)
Especially from Bendigo, that's not Melb or anywhere near by to the general populace. You'd need someone from Bendigo, there are not many that use SAU i know of.
Either way it's not exactly a subtle modded one. Simple things that attract attention - that car has it. Especially a BOV in plain sight like that :(
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
