Engine was built by a shop down bris, usual rb30, 25de head, spool rods, mahle pistons
its dont about 3-4000km's and she's spun a bigend.. going by the colour of the rods were thinking oil starvation? whats everyones thoughts...
tune was 360rwhp on 13psi with a t04z, engine was run in on the dyno and had been running sweet
Edited by 32rrr
https://www.sau.com.au/forums/topic/359111-rb30-failure/
pull the girdle off and lay the main bearings out in order and see what they look like.
ps. all the plugs are still in the crank? especialy adjacent to the damaged bearing..
Will be doing that tomorrow and checking everyones still where it should be
i just cant believe how much colour difference there is in the rods
Edited by 32rrr
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5735896
I built this engine. About 2.5 years ago.
N1 pump was used at customer's request. I suggested using a Tomei as we were building two other Tomei pump engines at the time and you can't really go past them for quality/reliability
The N1 pump was brand new. Collar was new and fitted by an engineer. We always check clearance on collars when we fit them.
It had a ROSS balancer too so not a harmonic issue I don't think.
Such a shame, that engine was destined to make some bigger numbers.
Although I can't prove any problem with the N1 pumps, we just stay clear of them now due to the pump failures we have seen.
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5738378
What was the rev limit on this engine and was the limiter regularly hammered? I am interested (worried) because an N1 pump has gone into my RB30 (yet to run). One reputable RB30 builder here won't touch N1 pumps because of a number of failures but others say that they are ok with a rev limit such as i am planning to use: 6,800rpm. Or is the "safe" limit lower on an RB30?? Engine above does not appear to have been highly stressed - planning to run 18 - 20 psi with a GT3540 and looking for around 300awkw.
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5738918
Reved to 7, limiter set at 7250, hardly hit the limiter.
To anyone with a N1 pump on any engine.. i seriously suggest changing it as the pressure gear just isnt thick enough in the area's where it needs to be.. i will use a stock rb30E pump before i use an N1 pump again
Car was run in on the dyno, was going strong untill she went bang, the oil pump is quite spectacular
Crank and 2 of the rods are throw aways, pistons will be reused just have to decide what to do, but for now a bog stock rb30e bottomend has gone in just to get the car mobil again.
when i can see the funnier side to it.. i'll throw up pics around the place, i really have to give it to the spool rods considering the heat damage that they have copped i honestly dont know how they didnt bend and leave the block
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5739959
I purchased a second hand N1 pump from someone on this forum (he took it out of his car because he was paranoid) and been using it ever since, the pump is 4 years old now and ive been using it in my RB30 for 3 years, its been to 2 different countries and traveled a LOAD of km's with revs up to around 7300 with stock balancer when racing. It has withstanded temps of -10deg where you HAVE to use anti freeze and also hot weather also.
I use a very soft rev limiter with the vipec and stock balancer but i ALLWAYS use the best oil... Motul.
Only different thing i did before installing it was lock tight the screws on the back.
N1 all the way IMO even after 100,000 km (road) its still going strong! just ran a 10 last month.
The N1 pump has served me great.
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5740613
Correct me if i am wrong but I THINK that when the gears gave way and siezed the engine must have had some torque behind it and kept spinning inside the pump and just shredded them away...
You can see there was a f load of heat inside there at one point :)
nice main bolts btw
Where the hell did the two flats go?
https://www.sau.com.au/forums/topic/359111-rb30-failure/#findComment-5740649
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
