Ok I just got word back from my ‘mole’ inside DoTaRS that there are some MAJOR changes planned for SEVS regarding vehicle emissions, and what’s worse, some of them will be retrospective and will apply to cars already complied!
1) Like the NZ import scheme, SEVS eligibility will soon be limited to cars that meet the Japanese ‘TA’ emissions scheme or later if they’re ex-Japan (that means no cars prior to about 2001 will be eligible for import). For the Skyline range, this will rule out all R32s, all R33s and virtually all R34s (did any R34s meet TA regs or were they all GF?), but V35 and V36 will still be ok. Evos prior to Evo 7 will be out. Supras will all be out. JZX100 Chasers will be canned, but JZX110s will be ok. US-built vehicles are not affected because their emissions regs are stricter than ours anyway.
2) Cars ALREADY imported under SEVS will be tracked down via NEVDIS (the national database for vehicle identification) and owners contacted. The plan is to make owners submit their vehicles for annual emissions inspections to ensure that their vehicles meet the regulations they were complied under. Cars complied under the old scheme prior to SEVS will be exempt, as will cars imported under the pre-’89 rule.
3) The plan is to move SEVS more in the green-car direction, so they will soon allow hybrid models of cars already sold here in Australia to be imported – for example, the Tarago is sold in Japan as the Estima Hybrid, that will be allowed for import.
Well there goes my business, unless I move to Nimbin and use the tree huggers as my new target market... :down:
Edited by Iron Chef
https://www.sau.com.au/forums/topic/359421-changes-to-sevs-in-the-pipeline/
any ideas on timing for this chef? i.e. can we go import crazy now on pre 2001 cars until this is made official?
better be an april fools f**ker
If its true tho Rhys, will it be worth owning an import that you can modify only basically so it passes emissions once a year?
Well it is actually closer to the truth then an april fools joke, many submissions (LINK) have been put forward for a few years now including as below from the Australian Automobile Association about 3 year old max cars to be imported.
Then you have the current submission LINK of the NSW MTA (image below) that if you are not a dealer you should only be allowed to import one car a year (it was one car every 2 years).
Its coming that is guaranteed, just look at the changes to Pre 1989 model cars and Personal Imports.
For the record, PRIMO passed on a copy-and-paste of my info to my agent in Japan, and from there it went around the auctions like wildfire, till I got a panicked call from another agent I use in Tokyo asking what the hell was going on! Evidently April Fools isn't a big thing in Japan, making them all ripe for the picking haha
sounds like you got a VERY STRONG bite out of it.
mind you ADR 79/02 is going to shake a few people. anything after 2008 ( I *think*) has to pass that one to gain entry.
as for the emmisions gag - like that one. reminded me of the drive by emmissions tests in california.
I think DoTaRS are taking a closer look at it Chris, particularly as Japan has changed its testing procedures for emissions in recent times to be more like what they do here.
The biggest issue is the cost of the test itself for late model cars, I've heard figures of $30-40K bandied about, which makes it bloody hard to recoup those costs without charging a crazy amount for compliance. Ideally, we want DoTaRS to recognise the Japanese testing procedures as being valid here, once that's done, it will be a matter of providing the Japanese emissions paperwork to pass, same as they do with cars from the US now.
Edited by Iron Chef
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
