  • Replies 482
well we BEEN ASKING him to get S2 box in 1 if not 2 .
may be he will now & save someone hassle lateon,
Spoke to Steve this morning and asked him to pack a couple of s2 4wd autos into the next container, still going to be a while away though :/
I nearly cried catching the bus this morning :/
thats sad i would love to give you a lift i know the pain of catching a bus:(
did the core plug upgrade to my cars transmisson on friday at work (got paid to work on my own car cool) made a big difference to the 1st to 2nd shift and the 2nd to 3rd is good as well
well reccomend for every one to do the same :)
Makes the car so much more drivable!
I was having big issues with flaring on the 1-2 change though, due to the Haltech not communicating with the TCM.
car on dyno today made 580hp@18psi on bp98 and then ran in on 109 and made 620hp@23psi which was weird so looked in muffler and it appears to shrink to 2 inches inside to try keep it quiet so we dropped the muffler ran it again and with no other changes it made 710hp@23psi on 109 so now just going to build a straight pipe when run 109 at shows and dyno comps and wind more boost into it they expecting it to maybe make close to 800hp in the end and then look for a new muffler thats less restrictive to hopefully get it over 600hp on pump fuel. but now its off to paint for the wagon for next 8-9weeks
Nice!!
Can I get a sound out for NIStune interest please?
-BigJim
-Blizzerd
-gersfan
-Darq
Have another person who is about to order one so if you know of someone else who wants a board, it doesn't matter what type it is for the group buy, get them on board :)
i had no windscreen wipers and i couldnt put any power down in the wet the day it just spun tyres mite be able to get out sunday arvo if wana get 2gethaor jim i live in rocko near hospital so just come on ova and ill take you for a spin
Edited by 260rsstagea
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
