will your rig be ready soon daniel?
expecting big things from this 60K + build.
hahaha 60K man i wish it had been that cheap basic rundown is car= $35000 (5 years ago), engine= $55000, paint= $15000, stereo= $25000
and to finish it how i want i still have $8000 of gearbox, $7000 of interior and if i can ever find a 32gts4 rear diff to make it awd again.
but it should be all back together stereo and all before christmas but wont be out for any cruises til feb as i am overseas for all of january but the old man will be taking it to motorvatio and will be on dyno there.
  • Replies 482
Meet Time 11ish am
as i am heading too Track on saturday ,
will not be going Sunday ,
Sunday is just a BBQ meet so most can just Chat & leave when you like ,
cheers Chuckie,
i will put BBQ spot up next few days
yo guys i have a misfiring prob with the stag.
i have changed my plugs , coilpacks now r34 gtr with low ks on them and cleaned my afm.
the old plugs where just copper bcpr6e-11 the new 1s that auto pro gave me are bcpr6es.
i have regaped my new plugs form .8 to .7
the misfire is only at idle and u can feel it more when in gear. was told by mel at evoR to take the throttle body off and clean it.
is there any thing else u guys can think of that might cause this?
i know a bit about cars but i not know what else it could be
Nice pics Dave - good to meet some new faces and (and some familiar faces), was a good day :) (Sorry - prob some double up photos.... )
Edited by 32godzilla
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
