  • Replies 482
Does anyone know where I can get my hands on a front bumper for a S1 and rough price as the fibreglass one on the Stag I recently got it stuffed and seems like cheaper to replace than repair? Prefer a Dayz one, but even a stock RS4 front would do.
Edited by Dingus
OK guys, 2nd last payment is pending and then I'm just waiting on gersfan.. if anyone knows him or how to get in contact with him please let me know or get him to contact me!
I shall allow him the weekend, if no response then I will place the order on Monday as we already have our minimum.
G`Day lads ,
just had the fun changing right hand front drive shaft,
not a bad job if the shaft stays as 1,
mine didn`t ,so had to find way to remove what was left in front diff,
after few rant`s i got it sorted,
you need to undo
sway bar,
bottom ball joint,
steering ball joint,
brake caliper & rotor,
i will add some more info soon,
i have old shaft so will look at costs of getting them serviced,
so if you need set we know costs,
cheer`s Chuckie.
i just sent it, sorry for the wait.. how do i find that ecu number?
should say it on the actual ecu
or get your vin fasted
ecu number..... i see you have a rs4s...
top off my head..
23710 0v800
or
23710 0v801
i have both of those
will let the 801 go if you need for 200, what i bought it for if you want to have a stock one just in case
Edited by Blizzerd
Ok all monies are in, I'm just trying to download Andreis' maps before I place the order but it's proving rather difficult :( He has an oddball ECU and they need a factory image for base programming.
I think my serial>USB converter is playing up and dropping the connection periodically :(
Does anyone have a proper USB consult cable that we could borrow? (i.e. doesn't need an adapter)
All sorted Jim and it wasn't as simple as the ECU number, I had to download the whole image from Andreis' ECU as it is an odd model and they haven't done one before.. It is a series 2 with a Neo engine but not the tiptronic auto, 25GT-X or something like that :blink: I sent the image to NIStune and just heard back that it's doable.
Oh and it was my serial>USB adapter that was playig up :( chuckies worked fine!
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
