  • Replies 42
Posted Images
http://www.skylinesaustralia.com/forums/topic/185569-m35-info/page__st__700__p__5363585#entry5363585
If youre looking to get a new key cut, the genuine nissan part for a key without the remote central locking component has the part number H0564-AU000; I bought them off an ebay seller for $33 plus shipping. Unsure if it was a good deal, but it was convenient. According to a quick google search, Sterling Nissan in the Adelaide Hills may have some blanks - unsure what price theyre asking. A 10 point 'Nismo' key should also work, if you can find one.
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5747251
From memory they are just over $200 new from Nissan. Not too bad considering what some people charge! Admittedly twice the price of my Falcoon key but then my Stagie is twice as nice as that car...
Nissan can get it cut for no extra fee if you have your key number (that's what I was told anyway). Programming can be done by the dealer or try it yourself:
key programming
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5747468
$200 isn't as bad as I thought, I would pay that, albeit reluctantly..
Guess I will put it on the list. Might have to buy a few as my Mrs loses keys every 2 weeks.
LOL, you don't need a new key, you need a new Mrs... :P
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5749225
My tag that come with the key has 05353, i cant find anything with google with that number. will have to click harder.... from the option catalog there were a few remotes that came with it.
Do you have a proximity immobiliser receiver (small black rectangular thing with rounded ends) with your key?
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5751284
This is all I can pull up in FAST regarding the key for Oct 2001 - Aug 2008 M35's.
As you can see in the bottom of the pic, there are 2 part numbers (H0560-4A000 and H0560-79930) meaning there are 2 different types.
I don't know which one your have nor what the differences are between the two.
Section H05-001 if you need to take it to Nissan so they can maybe cross reference them on an English displaying FAST :)
(I'm sure they were sold with Maxima's, 350z's etc over here)
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5751563
Sorry I should have been clearer. That number is the key profile- give it to Nissan when you order a key and they will cut it to the new spec instead of a key cutter copying an old worn profile off your existing key.
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5753094
  • 1 month later...
Just and update
Managed to get my hands on some old fobs - transfered to new shell+blade, cut and programmed to my car following the hand written pdf instruction found on this site.
Took almost 4 weeks of waiting, praying and lots of fights and silent treatment with the other half as to why I withdrew soo much money which could succumb to nothing. If anyone has used Nengun auctions which is another story.
I now have one key cut and programmed for myself and two spare complete keys surplus that just needs to be cut and paired to your car anyone needs it check the Stagea parts section.
Reason I ended up with three keys was because I was scared that i may be outbid so i bid on all three to maximize my chances and also being a virgin nengun bidder.
https://www.sau.com.au/forums/topic/359929-m35-spare-key/#findComment-5831127
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
