Well as the title states my catchcan vent blocked and the 32 started spewing white smoke... I get about 2 psi of boost and I'm wondering if the pressure has blown out my turbo seal...? If anyone could shed some light on this for me so I know where I'm at I'd be very appreciative.
https://www.sau.com.au/forums/topic/359985-blocked-catchcan-vent-killed-my-32/
How could a blocked catch can put pressure on the turbo's bearings?
The white smoke would be oil spewing back into the intake from the catch can... There's no way the bearings would "blow" from this...
Not entirely true.
Increased pressure in the crankcase will prevent oil returning from the turbo. However it is more likely you will see the smoke as a result of it in your intake first.
The can wasn't plumbed back into the intake... also I noticed, under the bonnet, oil dripping on my plastic sump guard from the turbz area... I hav'nt looked at anything yet but was also wondering if this would've done something to the engine? only drove a few hundred meters when I noticed the smoke
Have seen first hand what excessive crank case pressure can do to turbos, which is what you would have had with blocked breathers...as was mentioned above, oil in the turbo cant return to the sump and builds in the turbo core, it then pushes past the exhaust seal, in my case, the exhaust seal was shagged or had moved according to turbo builder and I had sh1t loads of white smoke, like you...
have you fixed the catch can?
take the dump pipe off the turbo and see if there is an evident oil leak from the seal. and same on the front, if you cant see any oil there, put the intake back onto the front and start the car to see if smoke starts pouring from the turbo exhaust, if it does turn the car off and see if you can see oil in the exhaust of the turbo.
let us know how you go
Yep, exhaust wheel will look 'wet' and you probably wont see this until the turbos off but oil will be weeping down the bottom of the front side of the exhaust housing, let us know how you go...mine wasn't caused by blocked breathers but excessive piston to bore clearance...same result - excessive crankcase pressure and a turbo that couldn't drain..
Edited by NSNPWR
  • 3 months later...
Well... new turbo ( already had ) and all exhaust and ceramic coating etc and still getting slight smoke out back from oil... maybe valve seals blown out..?? any help would be appreciated, dying here... pinch.gif
yeah I had some smoke after installing new turbo and ceramic coated dump etc went away after a few heat cycles, I assumed it was just burning off shit from new turbo and new coatings..
another time needed to put a restrictor in the oil feed of the turbo, because with Jun pump was pumping too much oil and pushing past the seal, hence blowing white smoke..
hopefully just one of those reasons for you :thumbsup:
If you seal the crank case gases in it will pressurise and can burn lots of oil, I've seen it happen before. Don't see how it would do anything to the turbo though.
I found oil in the mouth of the compressor side when I was putting a boost controller in and had to remove stuff to get to the actuator... hoping its from it sitting around for so long..?? stretching maybe but dont want to think I have to pull it all off again... also I have taken it for a couple runs before that and it was showing white at the end of the runs and a hint of blue due to not being mapped..
Edited by partyboy73
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
