here are some new items to add to the list :)
1. full set of nissan wiper - $50
2. 2 x rb26 timing belts (have done less than 5000km) - $50 each
3. 2 x rb26/30 timing belts (have done less than 2000km) - $50 each
4. front sway bar with linkages & brackets - $50
5. cometic metal head gasket (has done 30min of work) - $100
6. full set of led dash lights (for instrument cluster & centre triple gauges) - $50
7. interior a/c control unit - PRICE DROP $90
8. surge tank with bosch 044's & associated fuel 300psi lines & clamps - PRICE DROP $550
9. 17" forged Work BRS Poison wheels with bridgestone tyres - PRICE DROP $850
10.rear boot plastic trims which sit on the top of the rear tailgate - PRICE DROP $40
11.momo gearknob - PRICE DROP $60
  • Replies 386
Hey mate,
I'm after an R32 GTR Bonnet Latch.
Les . . Melbourne
______________
hi guys,
these parts are from my previous black R32 GTR, aka GO21LA! as pictured below...it was a very clean car, my mate bought the engine so i decided to wreck the rolling chassis as parts.
i will be adding to this thread a lot more parts over the following weeks, i just need to pace myself with the parts i sell so i can keep track of things :)
if you need anything else in particular, chances are that i’ll have it so just ask me (except for the chassis, front panels & rear subframe)
1. gearbox $900.00
2. front door trims $240.00
3. rear door trims $200.00
4. dash pad (no cracks or bubbles – perfect condition) $150.00
5. dash cluster with 180km/h speedo (showing 65000km) $200.00
6. doors (includes tinted glass & power window mechanisms) $350.00
7. front windscreen (with antenna) $200.00
8. rear tail lights $200.00
9. new ASI radiator (unopened in box) $170.00
10. mirrors $120.00 sold
11. front lip $200.00 sold
12. factory afm $70.00
It’s a Bing Lee sale where “everything is negotiable” :)
regards,
marko
0405 336 843
Marko.
Got an R32 GTR Bonnet Latch?
Les . . .
______________
hi guys,
1. gearbox $900.00
regards,
marko
0405 336 843
I received a call yesterday for the front windscreen and if u can read this post, I don't have your email as yet. To confirm, my email is markoradojcic@gmail$com
Once I get your postcode, I'll send you a quote on postage within 5min :)
hi all,
here is another quick update of parts left + new parts which i've added to the list:
1. gearbox - $600
2. front door trims - $160
3. rear door trims - $100
4. dash cluster with 180km/h speedo (showing 73000km) - $90
5. front windscreen - $90
6. rear tail lights - $100
7. factory afm - $50
8. blitz icolor dual solenoid dsbc boost controller (with user manual) - $500
9. attesa 4wd pump - $200
10.hicas pump - $70
11.dash vent (passenger side) - $40
12.left cv with knuckle assembly - $90
13.right cv with knuckle assembly - $90
14.drivers side window/mirror control - $50
15.sun visors - $10
16.complete boot trim - $80
17.instrument panel surround (does not have headlight switch) - $20
18.power steering line - $10
19.caster (radius) rods - $40
20.radiator overflow bottle - $10
21.passenger & drivers side door sill garnish - $40
22.door seal finish - $10
23.factory side skirts (black) - $150
24.front subframe - $30
25.bootlid rubber seal (no tears) - $10
26.power steering reservoir - $10
27.passenger side window switch - $20
28.os giken triple plate clutch - $1450
29.full set of nissan wipers - $50
30.2 x rb26 timing belts (have done less than 5000km) - $50 each
31.2 x rb26/30 timing belts (have done less than 2000km) - $50 each
32.front sway bar with linkages & brackets - $50
33.cometic metal head gasket (has done 30min of work) - $100
34.full set of led dash lights (for instrument cluster & centre triple gauges) - $50
35.interior a/c control unit - $90
36.surge tank with bosch 044's & associated fuel 300psi lines & clamps - $550
37.17" forged Work BRS Poison wheels with bridgestone tyres - $850
38.rear boot plastic trims which sit on the top of the rear tailgate - $40
39.momo gearknob - $60
40.bosch 044 fuel pump intank setup with factory cradle - $120
41.factory rb26 harmonic balancer - $100
42.heater hoses which sit behind the firewall (with hose clamps) - $30
if you unclear about any of these parts, you will find a pic of every single item throughout my thread!
im always open to offers :)
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
